Thread: "Gross" as opposed to "Net" Area Take-Off for Walls
    September 26, 2012
    USA
    132
    01:05 PM
    Question "Gross" as opposed to "Net" Area Take-Off for Walls
    Our estimators would like the flexibility of having both Gross and Net area values for Wall Finish Take-Off. We're getting the Net area easy enough, but we haven't figured out a way to post the Gross area. Does anyone know how we might go about extracting this information dynamically? Is it possible to query a hosted object's properties from the parameters available at the parent object level?
    Further Clarification:
    Gross Value - The total value of Raw Material (Not subtracting the openings for Doors, Windows,etc)
    Example: A 10'x10' Wall with a Door and a Window in it, will still post 100SF of Material (Door and Window ignored during calculation)
    Net Value - The total value of Actual/Cut Material (Subtracts the openings for the Doors, Windows, etc)
    Thanks - Dave
    6,389
    01:05 PM
    Quote Originally Posted by SuperDave View Post
    Gross Value - The total value of Material withOUT any openings removed
    Example: A 10'x10' Wall with a Door and a Window in it, will still post 100SF of Material (Door and Window Removed from calculation)
    Net Value - The total value of Material with openings removed.
    shouldn't net be with openings removed & gross without (see above)?
    September 26, 2012
    USA
    132
    01:05 PM
    Thanks Cell, I reworded the original post.
    "OMG I killed Revit"
    dzatto's Avatar
    5,273
    12:05 PM
    Couldn't you add a parameter (call it gross area) that multiplies the walls length and width?
    September 26, 2012
    USA
    132
    01:05 PM
    I've considered this approach, but I'm not sure it accounts for Extension distances and edited profiles. I could do something like this: 'Length' * ('Unconnected Height' + 'Top Extension Distance' + 'Base Extension Distance') but when an Extension value is Negative, the formula subtracts it, where in reality it may be adding height to the wall. This becomes a a bigger else/if statement and then we still haven't addressed profile edits.
    dzatto's Avatar
    5,273
    12:05 PM
    Well that sure complicates things.
    I could have sworn there was a thread on here about an add in or something that had to deal with wall areas and openings. I'll try to find it.
    Member feio's Avatar
    Decadent Lisbon
    450
    05:05 PM
    The SDK comes with an example that does exactly that, in a project named "MaterialQuantities".
    It uses a temporary transaction to remove all inserts in the host (get them with the FindInserts method).
    The logic is pretty simple (and awkward):
    1. create a transaction and start it
    2. get all inserts in the wall
    3. delete them
    4. get the material quantities without the inserts
    5. rollback the transaction
    The FindInserts is for HostObject, so Walls are included
    6,389
    01:05 PM
    BoostYourBim saw this and has an API solution if you still need something:
    Net and Gross Wall Area | Boost Your BIM - making Revit even better
  1. What's so "special" about "Specialty Equipment" ?
    Last Post: May 18th, 2013, 03:38 PM
  2. Show Room "Interior Fill" on an Area Plan
    By darryl in forum Architecture and General Revit Questions
    Last Post: August 29th, 2012, 01:25 PM
    Last Post: February 9th, 2012, 01:15 AM
  4. "Target" Room Area in Schedule?
    By cliff collins in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 08:27 PM
