Thread: Copy & Pasting using Paste Aligned to Same Place - not coming in at same place
    May 18, 2011
    Calgary, AB
    410
    11:32 PM
    We got a multi-file project using shared coordinates. All the projects have the same shared coordinate numbers - which is fine. We copy paste from one project into another and the elements don't land up in the correct location.
    Doing some digging the initial start up location is different between the files.
    The tool tip suggests that the elements can be copied between two projects using shared coordinates... but it's not using shared coordinates as its point of reference. Instead it uses the initial startup location as its point of reference. Can anyone confirm my thinking?
    Coeur d Alene, ID
    4,824
    10:32 PM
    Shared coordinates puts each project file at a certain place on a site....but it has nothing to do with the project center point within each model. So unless both projects were setup exactly the same, copy/paste won't work.
    133
    12:32 AM
    You could use the copy/monitor tool to copy in the stuff you need, delete it in the other model, and then tell the copy to stay and no longer monitor.
    Coeur d Alene, ID
    4,824
    10:32 PM
    What I usually do is add a line from a known grid intersection of both models and use that location to line them up....
  1. David Light: FormIt…Copy & Pasting
    Last Post: January 8th, 2013, 04:45 PM
  2. Revit OpEd: Paste Aligned Won't Play Along
    Last Post: December 13th, 2012, 03:15 PM
  3. Copy/Paste Alignment
    By john.warburton in forum Architecture and General Revit Questions
    Last Post: December 6th, 2012, 02:59 PM
  4. Component Paste Aligned to Different Level - Ends up in Same Place
    Last Post: October 1st, 2012, 06:04 PM
  5. Copy and Paste Text Tip
    Last Post: February 25th, 2011, 09:11 AM
