Thread: Turn off a specific Generic Annotations in specific MEP views
    June 13, 2013
    09:53 AM
    Hello everyone, I'm working with some MEP Families (some dialysis boxes). They got a Generic Annotation nested, but I only want to display it in some specific views. I've added a Visibility Parameter (a 'Yes/No' instance parameter) that turns it on/off, but in all views!!! If I go to the Annotation Categories and try and turn it off it won't even come up, and honestly that trick doesn't really work. SO MY QUESTION IS: is there any possible way of filtering a Generic Annotation? That's the only way that comes to my mind. It has to be either a filter or some sort of Visibility parameter that will only 'apply' in those views where it's being used. Does this exist? I can't find it.
    February 16, 2012
    Perth, Australia
    78
    08:23 AM
    You can use subcategories. Create a new subcategory for the annotation and then turn that subcategory on/off in vis. graphics in each view.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,474
    06:23 PM
    Depending on what the generic annotation shows you could also remove the annotation from the family and turn the information into a tag, and only use that tag in the views you want to see that information.
  1. How to get at specific point coordinates?
    By Xawier in forum Architecture and General Revit Questions
    Last Post: March 29th, 2013, 05:24 PM
  2. Specific Riser Height
    By npalmitessa in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 03:17 PM
  3. takeoff specific area
    By MichellGutierrez in forum Structure - General Questions
    Last Post: September 17th, 2011, 12:06 PM
  4. insert specific tag in family
    By ikinks in forum Architecture - Family Creation
    Last Post: May 5th, 2011, 05:33 AM
