Results 1 to 10 of 14
Thread: Exporting plan to dwg, including sections in 1 file
    Member bangobeat's Avatar
    April 14, 2011
    264
    12:42 PM
    Edited:
    How to export plan with sections to 1 dwg file? in my case i showed plan + section on sheet, and after import it gave me 4 dwg files.. Ideas?
    11:42 AM
    I think that maybe the dwg has used some xrefs that are imported as separate dwg's?
    Huge guess, I really wouldn't know. Haven't heard or seen this before...
    April 14, 2011
    264
    12:42 PM
    Any other guesses? Its pretty important in order to communicate with other construction architects in my office during my internship..
    "OMG I killed Revit"
    dzatto's Avatar
    5,275
    06:42 AM
    What are you doing exactly? Importing a DWG into Revit?
    If it is using Xrefs, then open the DWG and bind insert the Xref's. They will then be part of the DWG.
    Select the Xref, right click, select bind>insert
    April 14, 2011
    264
    12:42 PM
    Oh damn sorry, i am exporting from revit.. Such a pig making this mistake. I am Exporting from revit..
    dzatto's Avatar
    5,275
    06:42 AM
    Oh sorry. After rereading your original post that's exactly what you said. lol It's Monday.....
    Anyway, I guess you could export them to 4 drawings, then copy clip them into one drawing? Sort of a pain, but it gets everything into one DWG.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,574
    04:42 AM
    individual views in Revit export as individual .dwg files in both 2011 and 2012 Revit as far as I can see. You'll need to combine the .dwg files in Acad when you're done I'm afraid
    11:42 AM
    I feel like a dumbass, completely misread the OP.
    This is a real stupid and tricky thing (which I wished that the Factory would finally fix): You need to uncheck the "Xref views on sheet" checkbox in the Save As screen (sorry, I don't have Revit on me right now, but it's located in the screen where you select export path and name, bottom of the screen).
    This is by default on, which is IMHO actually completely moronic because NOBODY I know wants to Xref the views on an exported sheet. If we wanted the views to be exported seperately, we would probably select those to be exported).
    But, uncheck this and you'll be off...
    dzatto's Avatar
    5,275
    06:42 AM
    And you have just been nonimated for POTM. Not that I use that, but that's a damn good tip / trick to know about.
    Alex Cunningham's Avatar
    Northern California
    3,576
    04:42 AM
    I was kinda thinking this is what he was talking about but I had it backwards.
  1. Area plan as occupancy plan and schedule
    Last Post: February 5th, 2016, 09:16 PM
  2. Blue Lines - Exporting
    Last Post: May 11th, 2011, 09:05 PM
  3. Exporting Revit to gbxml
    By ajbpow in forum MEP - General
    Last Post: April 18th, 2011, 02:41 PM
  4. Drafting View Sections VS Building Sections
    Last Post: February 21st, 2011, 03:57 PM
  5. Exporting DWG and DXF causing fatal error
    By rsloyer in forum Architecture and General Revit Questions
    Last Post: December 14th, 2010, 01:43 PM
