Thread: How can I get this parameter into a tag?
    Member Defiant1's Avatar
    March 26, 2011
    Terra Firma
    149
    04:08 AM
    Ok. I give.
    I've got embed plates in CIP columns (see screenshot, you can see the plate beyond...(green)
    In properties, the hardcoded "Elevation" parameter is displaying exactly what I need/want to see.
    Is it possible to get a tag to pick up the "Elevation" value?
    If yes, How? (Please, step by step...type s-l-o-w-l-y so I can keep up)
    If no....that would be typical for me.....seeing what I want but can't have it.
    If there IS an answer...I know it's going to come from here.
    Thanks!
    Nantes, France
    1,381
    11:08 AM
    You need to set a SP in the nested family.
    Make the plate geometry attached to ref planes that are not the 2 from the template. Assign a SP to the distance between the RP at center of geometry and the RP that defines origin. SP will be by instance. Beware of directions for correct behavior when loaded in the host.
    In the host family, add the same SP, select the plate, and in properties palette, look for the tiny button on the left. Click and choose the SP you've added. The insert point of the plate must be set to the ref level of the host.
    Now you have the elevation of the plate driven by a SP in the host. Create a tag for this SP. You're done.
    March 26, 2011
    Terra Firma
    149
    04:08 AM
    Thank you Julien...not only for the solution, but for the detailed explanation.
    I appreciate it!
    Nantes, France
    1,381
    11:08 AM
    My pleasure ;-)
  1. select by parameter? curtain wall panels' materials by parameter, by type or family?
    Last Post: January 24th, 2013, 02:20 PM
  2. yes/no parameter driven by another yes/no parameter
    By voland in forum Architecture - Family Creation
    Last Post: October 18th, 2012, 03:12 PM
  3. Family Shared Parameter "Group Parameter Under" in a Project
    By Aretap in forum Architecture and General Revit Questions
    Last Post: August 10th, 2012, 10:18 PM
  4. Using "Family Type" Parameter as a Shared Parameter
    By jmwatson84 in forum Architecture - Family Creation
    Last Post: May 8th, 2012, 09:36 PM
  5. Convert Project Parameter to Shared Parameter
    Last Post: January 5th, 2011, 07:35 AM
