Thread: Ceiling Grid
    Senior Member domsib's Avatar
    April 30, 2012
    586
    01:44 AM
    Ceiling Grid
    I've never worked on the Electrical side of Revit so I've decided to have a practice and see what I can pick up.
    I've drawn a few walls and added doors and windows. I have 2 standard levels; level 0 and level 1.
    Level 0 being the ground floor and level 1 being 4m above this.
    I've drawn a 600x600 ceiling grid in all of the rooms at a height of 3.2m but it does not show up in my plan view.
    I see it in my 3d view, can anyone tell me how I get to view it?
    If I go to my VG the ceilings are checked.
    6,329
    08:44 PM
    in the PB, scroll down your view list a bit and look for ceiling plans. If you don't have one, go to the view tab -- plan views -- reflected ceiling plan and create a new one.
    Member UKN's Avatar
    February 16, 2011
    Las Vegas, NV
    71
    05:44 PM
    Check your view range in the RCP, and make sure that the top plane is set to level 1 (anywhere above your ceiling), and that cut plane is set below 3200 from level 0. Should work then.
    Edit: Aaaah, yeah, make a ceiling plan first
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    465
    06:44 PM
    RCPs and Floor plans are created separately of each other. In the PB, Underlay is set to none and Underlay orientation is set to Floor or RCP depending on the plan view type created, you can switch those, but it wont display properly. I heard in 2013 you are suppose to be able to change underlay to the same level and be able to see the floor plan view and RCP but I can never get it to work. Mechanically, I typically use a "working ceiling" to lay out the diffusers, same for lights and anything ceiling hosted.
  1. Centering ceiling grid
    By GMBailer in forum Architecture and General Revit Questions
    Last Post: February 7th, 2018, 09:23 PM
  2. Ceiling Grid won't move anymore
    Last Post: April 26th, 2017, 08:25 PM
  3. Ceiling Grid - Noob question
    By Ant123 in forum Architecture and General Revit Questions
    Last Post: February 11th, 2013, 04:56 PM
  4. Ceiling Grid on my lighting sheets.
    By DMapes in forum MEP - General
    Last Post: May 10th, 2012, 10:13 PM
  5. Revit OpEd: Ceiling Grid in Navisworks
    Last Post: August 22nd, 2011, 04:00 PM
