Thread: Sweep Roof sheeting IBR
    April 2, 2013
    11:33 AM
    Hi guys I'm trying to sweep a IBR roof sheeting, but I'm new to family creation. I checked how to do it at this link GoodRevit.com • View topic - Make and Quantify Profiled Roof Sheeting but it does not give me enough info to create the sheet.
    Can someone help me please
    I use Revit Structure 2012; Architecture 2013
    09:33 AM
    I wouldn't go with the beam systems since this will give you problems with sloped or vertical faces. I would suggest to create Curtain Panels and use Curtain Walls / Curtain Systems. This way you can have the same workflow for all options.
    Here's an example to reverse-engineer.
  1. Roof based family inserts 'one level' above roof?!
    By dylanr69 in forum Architecture - Family Creation
    Last Post: February 4th, 2013, 01:53 PM
  2. Mansard Roof . . . How to get the Roof Thickness to be Consistent
    By kamranmirza in forum Architecture and General Revit Questions
    Last Post: September 4th, 2012, 12:43 AM
  3. Calculate Roof Area for Slope Glazing roof
    Last Post: October 31st, 2011, 06:54 PM
  4. sweep did not work with me to draw cornice along roof
    Last Post: August 25th, 2011, 08:30 PM
  5. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
