Thread: Set Material to ByCategory via API?
    Junior Member Steve Faust's Avatar
    April 4, 2011
    Colorado
    46
    09:43 PM
    Once a material parameter is set in a family is there a way to set it back to <ByCategory> via API?
    The parameter.set method takes an ElementID, but won't take 'Nothing' as an argument...
    Member krispy5's Avatar
    68
    02:43 PM
    you need to set the parameter to a "null" ElementId... in C#:
    Code:
    Parameter param = elem.get_Parameter("Material");
    if (param != null)
         param.Set(new ElementId(-1));
    the above assumes you already have a variable "elem" of type Element initiated with a valid Element and then sets a parameter called "Material" to an empty ElementId
  1. New API utility
    By feio in forum Third party Add-Ins, API and R&D
    Last Post: June 18th, 2014, 09:44 AM
  2. My first API blogpost
    By mdradvies in forum Third party Add-Ins, API and R&D
    Last Post: April 5th, 2011, 02:02 PM
  3. Being able to set a displayname
    By sander.obdeijn in forum Forum Suggestions and Feedback
    Last Post: February 23rd, 2011, 10:31 AM
  4. Wall by API
    Last Post: January 19th, 2011, 09:34 PM
  5. The new Autodesk Support Request set up STINKS.
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 01:14 PM
