Thread: Tagging Curtain Walls as Windows
    January 27, 2011
    KC,MO
    346
    05:50 AM
    I am trying to tag curtain walls to create a window schedule, and I can only get the wall type tag to show up. Is it possible to tag curtain walls with window tags instead?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,534
    03:50 AM
    Quote Originally Posted by stl4310 View Post
    why not just make a curtain wall tag to look like the window tag you want to use? Is this just a visual thing or do you have some other reason to want to use a window tag?
    January 27, 2011
    KC,MO
    346
    05:50 AM
    I could do that, it's mostly a graphic thing...I guess to create my window schedule (multi-category?) I could create a filter to include curtain walls?
    10,528
    05:50 AM
    There are a ton of things to think through regarding this:
    Curtain Wall "Types" wont correspond to any actual type of mullion configuration or elevation, so in effect: Either way you do it will be manually coordinated. Since that is the case, i recommend a Generic Annotation placed in a Model Group with the Curtain Walls. At least then you can select all of the model groups, and tell them to place the attached detail groups in certain plans. Its manual that when you make a new curtain wall configuration (group) you have to change the GA, but thats no more manual than having different Curtain Wall "types" since they wont associate anyway.
    4,415
    11:50 AM
    Along with worksets, curtain walls were another "evil of Revit" myth I had to move our office away from, so in the early days it was "make the CW (wall) tag look like the window (window) tag" - but now, thankfully, it's "well that'd be curtain walling, so lets have a CW (wall) tag that reads their (instance) mark, and elevate them individually, accordingly" - and like wise :
    we've gone from trying to include the two in one schedule, and now have one for each - that way then we have type-based schedules for windows (for counts & design management), instance-based schedules for windows (for itemised data, ie. ironmongery, finish, etc) and an instance-based (wall) schedule filtered by type mark (CW) for our curtain walls.
  1. Exterior Finish Tagging
    Last Post: July 14th, 2011, 04:03 PM
  2. Curtain Wall inserts into walls as windows - finish returns
    Last Post: May 24th, 2011, 02:39 PM
  3. Custom/Standard Doors in Curtain Walls?
    By NLG in forum Architecture - Family Creation
    Last Post: April 12th, 2011, 06:39 PM
  4. Curtain walls / window mitres..
    Last Post: March 25th, 2011, 10:45 AM
  5. Tagging Plumbing Fixtures
    Last Post: January 27th, 2011, 04:23 PM
