Thread: curtain wall won't attach to roof
    October 20, 2011
    UAE
    169
    02:09 AM
    Exclamation curtain wall won't attach to roof
    Hello everyone!!!
    I have a problem attaching my CW to a roof. An error which says <<Can't make type "3D PANEL WITH LAYERS : AIW 230mm INTERNAL".>>.
    this is just a multi layer panel family that I've created earlier - it consist of 3 extrusions made from an elevation view and attached to ref planes (top, bottom, left, right)....as well as attached from Ref. Level to thickness defining ref. planes.
    I tested an empty file with default solid panel - it works ... but with my compound panel family it won't attach. Now I wonder if there is any constraints from the family editor which may conflict with one another - or what?
    October 20, 2011
    UAE
    169
    02:09 AM
    62 views and no answer ... hopeless spotless
    April 12, 2011
    Chicago, IL
    534
    04:09 PM
    I'm guessing your roof is at an angle which is causing your panels to become non-rectangular. Custom curtain panel families cannot make those shapes which is why you're getting that error. I haven't messed around with them too much, but I think adaptive components are the way to make those shapes.
    October 20, 2011
    UAE
    169
    02:09 AM
    thanks ... I messed around today but it didn;t work .. I'll try adaptive tomorrow
  1. █ Curtain Wall - Adjusting multi-storey wall from the bottom/ base... █
    By Spinalfarm in forum Architecture and General Revit Questions
    Last Post: November 8th, 2012, 07:41 PM
  2. Curtain Wall in a group, wont cut wall
    Last Post: October 5th, 2012, 01:06 PM
    Last Post: July 19th, 2012, 03:15 AM
  4. Sticky Notes: Curtain Wall Basics - Empty Curtain Panel
    Last Post: June 14th, 2012, 02:45 PM
  5. roof to wall
    By daemonhassan in forum Architecture and General Revit Questions
    Last Post: January 15th, 2011, 03:37 PM
