Thread: Linked Revit File - Show In More Detail
    Senior Member domsib's Avatar
    April 30, 2012
    586
    12:59 AM
    I have a Revit Model from an architect which I have linked into our project so I can begin adding M&E services to it.
    I have created a couple of 3D views of the model to help me coordinate my services.
    The model when linked shows as grey in colour and not in much detail (just a thin line), is there any way to enhance the detail of linked models.
    Thank You
    April 12, 2011
    Chicago, IL
    542
    07:59 PM
    Sounds like it's set to a different phase. You can set the phase filter to Show Complete to show everything. You should also try selecting the link and going to "phase mapping" under the type properties. Make sure all the phases are setup correctly between the projects.
    April 30, 2012
    586
    12:59 AM
    Quote Originally Posted by chris.macko View Post
    OK I have done both as you suggested but I still get a faint building model. I am wondering if this is supposed to happen sort of like autocad does with Xrefs, bringing them in faint.
    I would just like to know how I get the building to look as it does on the architects model, but when linked in. Colours etc.
    March 20, 2012
    Austin, Texas
    224
    07:59 PM
    Quote Originally Posted by domsib View Post
    Try changing your view discipline to Coordination and your visual style to Shaded.
    April 30, 2012
    586
    12:59 AM
    Quote Originally Posted by Aaronb View Post
    Yep, this sorted it. Thank You.
  1. Can callouts show up through linked views?
    By need4mospd in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2016, 06:37 PM
  2. Linked CAD detail won't show on floor plan
    By truthjusticeUSAway in forum Architecture and General Revit Questions
    Last Post: November 1st, 2012, 05:03 PM
  3. Architects file linked into Interiors File
    Last Post: July 2nd, 2012, 09:25 PM
  4. Insert a Linked Revit File
    Last Post: May 1st, 2011, 07:08 PM
  5. Insert linked revit file
    Last Post: January 7th, 2011, 02:30 PM
