Thread: Zooming/Lines Glitching
    United States
    1,153
    04:24 AM
    Does anyone else have an issue with lines glitching when zooming in as they used to a few releases ago? Where you zoom in and the lines look like they are not parallel and appear to move around and look odd every time you scroll in?
    We have this happening in a particular project in 2013. I have not noticed this in any other project yet. I believe it was upgraded from 2012.
    Junior Member theclaus's Avatar
    June 7, 2012
    34
    05:24 AM
    Usually this has happened to me when I import a civil CAD drawing that has HUGE extents and I get the REVIT warning about it. Have you linked any CAD drawings?
    February 18, 2013
    10
    01:24 PM
    Hi There.
    Did you guys find a solution to this problem? i have the same problem, my dwg is in the visibility graphics under the Imported Categories tab and switched off. If i switch it on i still cant find it anywhere even 3D, zoom to fit nothing.
    any advice will be much appreciated.
    Member RsqPrincess's Avatar
    October 3, 2011
    Wisconsin, USA
    60
    06:24 AM
    Hey
    We're having this problem with a model right now. The CAD file was massive (an import, not a link). I've since deleted the CAD file, but my walls and columns are still glitching as I zoom in and out. Is there any fixing this? What do you do?
    thanks!
    February 17, 2011
    Raleigh, NC
    193
    06:24 AM
    Ensure your model isn't too far away from the project base point.
    890
    09:24 PM
    I had this issue recently also.
    I was able to "fix" it simply switch the view that is bugging out between "geographic north" and "project north" and it fixed itself up.
    It wouldn't have been so bad if it was just a graphics glitch, but it seems to carry all the way thru printing even though the elements/lines are actually aligned on each other in reality, the graphic bug was causing the print to also print the graphic error. But when you measure from one line to the next in the view you get a distance of zero. Strange bug, I couldn't find what was actually causing it, but toggling between geographic and project north seemed to fix it.....
  1. problem of zooming out with cad imported?
    Last Post: February 21st, 2014, 07:54 AM
  2. linked dwg file "disappears" when zooming in view
    By jh75 in forum Architecture and General Revit Questions
    Last Post: February 4th, 2013, 12:41 AM
  3. Limits on Zooming in?
    Last Post: June 4th, 2012, 05:58 PM
  4. Blinking screen when panning or zooming -GPU issue?
    By shurik3n in forum Hardware and Infrastructure
    Last Post: January 17th, 2012, 07:39 AM
  5. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 07:25 PM
