Results 1 to 10 of 10
Thread: Changing Imperial to Metric
    March 23, 2011
    09:24 AM
    Hello there,
    Im a noob in revit and can't understand the dimensions I input in Revit because everything is in imperial and the system I use is metric.
    Can someone tell me how to change the standard measurements from imperial to metric?
    Thank You
    United States
    1,153
    10:24 AM
    Manage -> Project Units
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,529
    09:24 AM
    Quote Originally Posted by archandis View Post
    Hello there,
    Thank You
    Project Units and change Length to the metric value you want. In Revit 2011 Project Units is on the Manage tab
    Kingdom of Denmark
    4,236
    06:24 PM
    Archandis, welcome to the forum.
    As alreay suggested, you can change the project units. But maybe it was a better idea to start out with the metric template that ships with Revit ?
    If you didn┤t install the metrics already, you can download them from the Autodesk website
    Senior Member willsud's Avatar
    Ambleside, Lake District, UK
    961
    05:24 PM
    And of course, here in the UK where clients often still think in Imperial but the government insists that all regulatory applications are only in Metric... you can still enter dimensions in Imperial even when the project is created using a Metric template.
    Revit happily accepts 6'3" or even =6'3" + 100 (which gives 2050 with units set to Metric and mm)
    Member Mike Ferrell's Avatar
    London, Ontario, Canada
    60
    12:24 PM
    William, Interesting that the UK is in the same situation that we are here in Canada. Metric is the official form of measure so all government projects have to be in Metric. However at any building supply store all the products are in Imperial, perhaps because a lot of stuff comes from the USA, so most contractors prefer drawings in Imperial. As the building supplies are generally available in imperial sizes I use the Imperial Revit Library and have a dimension style set to use Metric units for dimensioning a "Metric" project.
    961
    05:24 PM
    Didn't know that Mike, thanks - how interesting.
    Looks like we will all have to be 'bilingual' for many years to come
    November 18, 2013
    Kurdistan, Iraq
    04:24 PM
    GO to Option>File Location, change the location of template from US Imperial which loacted (:\ProgramData\Autodesk\RVT 2014\Templates\US Imperial ) To US metric which located in (:\ProgramData\Autodesk\RVT 2014\Templates\US Metric\ ) for each templat\ .
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    255
    05:24 PM
    USA, Liberia, and Myanmar. Everywhere else uses metric. What are the Americans thinking?
    February 6, 2014
    06:24 PM
    Quote Originally Posted by john.warburton View Post
    They aren't/weren't thinking...
  1. convert metric to imperial
    By xvitrum in forum MEP - General
    Last Post: May 27th, 2011, 07:25 PM
  2. Changing Pattern to Region
    By pcamliti in forum Architecture and General Revit Questions
    Last Post: May 24th, 2011, 08:58 PM
  3. Imperial Type Catalogues
    By KiwiCodes in forum Architecture and General Revit Questions
    Last Post: March 31st, 2011, 09:58 PM
  4. Linestyles - Changing Names
    Last Post: March 8th, 2011, 01:09 AM
  5. REVIT- Imperial or Metric
    By RabbitHole in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 19th, 2011, 08:52 PM
