Thread: Walls not showing in structural elevations
    "OMG I killed Revit"
    dzatto's Avatar
    5,234
    04:55 PM
    I already posted this at "that other site", but everyone is here...so....
    Whenever I cut an elevation or section, then change it's discipline to structural, the walls disappear. I can't figure out how to keep that from happening. I checked all the usual suspects, and nothing is working. If I change the discipline back to architectural, the walls come back. Any ideas?
    Alex Cunningham's Avatar
    Northern California
    3,567
    02:55 PM
    This is due to the fact that the wall are not set as bearing walls. Arch has their own walls and Struct has its own walls. If the Arch wall has the "bearing wall" check in the instance properties it will display the walls when you set the visibility to structural. You could also dawr structural walls is Revit Structure.
    Moderator mark b's Avatar
    NSW Australia
    1,430
    07:55 AM
    Hi dzatto
    glad you made it over.
    Don't you have to put walls in as structural. Under structral on ribbon
    or
    change the walls "structural usage" in wall properties to strutural
    and it will work
    oops to late !!
    dzatto's Avatar
    5,234
    04:55 PM
    Wow, I feel stupid. I checked everywhere, but it never occurred to me to make sure the walls were structural. I don't run into this problem unless I'm doing a CMU block building. Thanks for the replies guys. Now if I can only get my damn IT guy to unblock the site at work, I'll be on here way more often. lol
  1. Accent Striping in Architectural Elevations
    Last Post: June 11th, 2015, 03:04 PM
  2. Offsets, Default Elevations, and Elevations
    By echo in forum MEP - General
    Last Post: January 10th, 2012, 11:20 PM
  3. Interior elevations and elevation callouts
    Last Post: December 28th, 2011, 09:25 PM
  4. Crop Region in Elevations
    Last Post: May 27th, 2011, 02:46 PM
  5. Elevations
    Last Post: March 31st, 2011, 12:32 PM
