Results 1 to 7 of 7
Thread: Floor finish (timber) not showing in render view
  1.    #1
    July 28, 2019
    3
    04:34 PM
    Hello! I'm trying to render my view in Revit, but for some reason my timber flooring is not showing. I've attached screenshots of the properties and settings and hopefully someone can help me!
    Attached Thumbnails Attached Thumbnails Floor finish (timber) not showing in render view-capture1.png   Floor finish (timber) not showing in render view-capture2.png   Floor finish (timber) not showing in render view-capture3.png   Floor finish (timber) not showing in render view-capture4.png   Floor finish (timber) not showing in render view-capture5.png
    Floor finish (timber) not showing in render view-capture6.png   Floor finish (timber) not showing in render view-capture7.png
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,277
    08:34 AM
    The only thing I can think of is that your wooden floor is inside the floor below it. You wooden floor is at 0 from the level and I asume you have a concrete floor at the same level as well. Try moving the wood 10mm or so up and see what happens.
  3.    #3
    July 26, 2019
    DFW, Texas
    13
    01:34 AM
    Yes, that was my first thought, too--that the finish floor was part of the Core, and not above that level.
    You might check to see which Bump map is applied to your Render material, too.
  4.    #4
    July 28, 2019
    3
    04:34 PM
    Thanks for the replies. I kind of cheated with this one so I actually only have one flooring and put the timber finish on it.
  5.    #5
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,453
    12:34 AM
    It looks like the floor is existing. Is the view (and the furniture & casework) new? If so, you likely need to change the views phase filter to "Show Complete". Unless you've changed settings, by default existing elements (which look like your walls, floor and ceiling) will use the material set in the phase overrides.
  6.    #6
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,186
    02:34 AM
    Quote Originally Posted by jmk View Post
    This is my guess also.
  7.    #7
    July 28, 2019
    3
    04:34 PM
    Thanks! I'll give that a try
  1. Floor highlight in floor plan view not showing
    By m b in forum Architecture and General Revit Questions
    Last Post: September 5th, 2018, 01:30 PM
  2. Continuous finish from floor to wall to floor
    By Tom Newsom in forum Architecture and General Revit Questions
    Last Post: June 17th, 2017, 12:54 PM
  3. Callout view showing floor beneath, but sheet it is referencing is not...?
    By Dynamek in forum Architecture and General Revit Questions
    Last Post: May 28th, 2015, 12:10 PM
  4. View showing wrong floor
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 7th, 2015, 10:32 PM
  5. Finish Render
    By andyl0193 in forum Architecture and General Revit Questions
    Last Post: May 24th, 2012, 06:27 AM
