Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: Revit to Lumion / Pixelated
    June 25, 2016
    94
    09:52 PM
    Hi everyone,
    I’m testing Lumion with a high resolution graphic card (Geforce 1070). I usually import files from Revit 2017 using the higher resolution available and still, my building looks very pixilated (while trees and objects added by Lumion are not). This tends to be more evident when using ornaments (you can see that in my photo)
    Thanks a lot
    Attached Thumbnails Attached Thumbnails Revit to Lumion / Pixelated-lumion.jpg
    Kingdom of Denmark
    4,221
    10:52 PM
    Your screen shot shows that you are in "build" mode, and thus you can´t expect a perfect resolution. However, you may be able to crank it up a little if you play with the settings.
    Attached Thumbnails Attached Thumbnails Revit to Lumion / Pixelated-lumion-setteings.png
    June 25, 2016
    94
    09:52 PM
    Quote Originally Posted by Munkholm View Post
    Thanks Munkholm for your reply
    I've actually set up the editor resolution to 100% and in play mode the resolution is quite the same. Do you think is related to revit or to how I import the files from there? Because all that I've done with lumion looks great while the actual revit model is quite disappointing.
    In any case, as a Lumion user, do you feel that the resolution that you see in my photo is normal or is there actually a problem ?
    thabks a lot
    June 25, 2016
    94
    09:52 PM
    A quick update,
    I think actually the main problem is that the shadow is not linear, it should be in this case but its not. I was able to soften it up editing it on photo mode but I think is not normal. In any case is the first time I see this in bulid mode
    Any help will be highly appreciatted
    Attached Thumbnails Attached Thumbnails Revit to Lumion / Pixelated-capture.jpg
    December 13, 2010
    Ambleside, Lake District, UK
    950
    09:52 PM
    I am just using a trial of Lumion 8.3 and I have seen the same jagged shadows in some models in Build mode, usually when a line such as a gutter is near horizontal.
    However when rendered the shadows appear fine.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    04:52 PM
    Yeah, that is just Lumion's way of reducing computer resources in build mode. If it happens in Photo of Video mode on the output image or video do some research on Lumion's shadow correction and range.
    December 13, 2010
    950
    09:52 PM
    Thanks 'Kid'
    I've noticed that there are quite a few things Lumion probably runs pixellated or slightly fuzzy - cloud reflections for example, or jerky animation to minimise resources - possibly even the moiré patterns on roof tiling in this screenshot - I was a bit concerned that these would remain when rendered but the output is extremely good quality even at modest resolution settings (see link to Vimeo video):
    May 22, 2012
    Connecticut
    185
    04:52 PM
    Quote Originally Posted by willsud View Post
    Thanks 'Kid'
    Yeah, ever since the release of 8.0 (which, to be fair, increased the quality immensely) the build mode and render preview are pretty different from the output results.... Which I am okay with haha!
    willsud likes this.
    229
    04:52 PM
    I do a lot of live design reviews and have found "build-space" lacking due to the issues described above. The photo view is no better. The renderings are fine, but that doesn't cut it when walking through a space with a client. Quick samples attached.
    Attached Thumbnails Attached Thumbnails Revit to Lumion / Pixelated-lumion-kitchen.jpg   Revit to Lumion / Pixelated-house-lumion-photo-mode-before-render-2.jpg
    229
    04:52 PM
    Quote Originally Posted by therevitkid View Post
    yeah, ever since the release of 8.0 (which, to be fair, increased the quality immensely) the build mode and render preview are pretty different from the output results.... Which i am okay with haha!
    nice video!
  1. Revit Kid: Lumion 8 - Teaser Image ...
    By The Revit Kid in forum Blog Feeds
    Last Post: November 27th, 2017, 12:15 PM
  2. What Revit Wants: Feel The Space - The Lumion 7 Review
    By luke.johnson in forum Blog Feeds
    Last Post: December 8th, 2016, 10:45 AM
  3. Replies: 0
    Last Post: April 13th, 2016, 04:16 AM
  4. New Lumion exporter plugin for Revit
    By FBlome in forum Rendering and Gallery
    Last Post: March 31st, 2012, 12:46 PM
  5. lumion and revit compatibility
    By asm2011 in forum Rendering and Gallery
    Last Post: November 8th, 2011, 01:37 PM
