Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By Robin Deurloo
  • 2 Post By snowyweston
Thread: Render problem
    December 27, 2011
    152
    07:11 PM
    Render problem
    Can someone tell me why the walls comes out looks like it's wrapped in nylon?
    July 7, 2011
    Rotterdam, Holland
    1,165
    07:11 PM
    I'm guessing a low quality render with shiny materials.
    cganiere likes this.
    December 20, 2010
    1,045
    01:11 PM
    yes, check the size of your crop, when you first create the view it is only a 4x6 box, select it click edit crop size, scale and go up to your desired final output size. then in your render settings try 150dpi, search the forum for optimum settings, don't just click high or best, usually takes to long and doesn't look much diff. then a slightly tweaked draft setting, upping the anti-aliasing and smooth shadows.
    December 21, 2010
    C.LONDON
    4,353
    06:11 PM
    No one will enjoy cooking at those hobs.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    11:11 AM
    Fix your gloss and reflections on the material. I know we all want cabinets to be clean, shiny and slick in person but Revit has always had issues with spectacular glossy/reflective materials.
    December 21, 2010
    C.LONDON
    4,353
    06:11 PM
    Perhaps I've only ever imagined as much, but where
    Quote Originally Posted by rbcameron1 View Post
    I've always found that to be the case where/when bumps on/from other materials get involved.
    Render an all-glass/chrome scene and everything is pretty much super-smooth-shiny-spangly - until you throw in something that will "scatter" the light (even the smoothest of gypsum walls) and then you're away with the fairies.
  1. Render in cloud problem
    By lamyazz in forum Architecture and General Revit Questions
    Last Post: June 1st, 2017, 03:24 PM
  2. Render in cloud problem
    By lamyazz in forum Rendering and Gallery
    Last Post: May 29th, 2017, 09:19 PM
  3. Background Problem in render cloud
    By netroger in forum Architecture and General Revit Questions
    Last Post: February 19th, 2015, 07:38 PM
  4. Render problem
    By cve60069 in forum Architecture and General Revit Questions
    Last Post: January 5th, 2013, 05:03 PM
  5. render problem
    By mimezgi in forum Architecture - Family Creation
    Last Post: September 30th, 2012, 09:56 PM
