Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree2Likes
Thread: 2017 - Best rendering software for Revit
    December 3, 2012
    Fernandina Beach, FL
    57
    02:51 AM
    I come with a visualization background and have been very dissatisfied with the output from the native Revit Rendering Engine. I've read the past iterations of similar threads and no one, I found, has posted about this topic in 2 years. Does anyone know of other rendering engines or rendering plug-ins which really enhance speed and image quality and remove grainyness? Again, coming from the background I have, I know Maxwell, 3DSMax, Vray, Lumion, Twinmotion, Octane, Iray...etc...these are all very time intensive renders. In my mind, I am searching for the something like the speed and quality of the Sketchup plugin- Shaderlight.
    So to revisit the topic, for any of the Visualization Artists who use or are given Revit models, what are you using?
    Thanks,
    Steven
    October 2, 2016
    1
    02:51 AM
    Quote Originally Posted by stevenpapke View Post
    Thanks,
    Steven
    Have you looked into the "new" vray for revit?
    https://vray.us/vray-revit/
    Sent from my SM-G930V using Tapatalk
    uaifestival likes this.
    December 3, 2012
    57
    02:51 AM
    I did the beta, and it worked pretty nicely, agree its one of the better choices today - I am looking for others tho. I recently downloaded the Vray trial, and due to a deadline I wasn't able to make it work for my needs. The sun and interior lights from revit which worked fine in the rendering engine went dark on me in Vray, despite converting them. I tried the sun, but couldn't recall the trick in time which worked on a deadline.
    January 18, 2014
    122
    01:51 AM
    I use Lumion currently and I can't figure out what you mean by time intensive. Are you producing movies or still images? My still images take seconds for 1920 x 1080.
    Member FBlome's Avatar
    Menlo Park, California
    90
    11:51 PM
    10,127
    01:51 AM
    "Grainyness" (sic) sounds (to me) like you are new to rendering in revit, and turned the resolution up, but didnt actually make the image any larger. So its probably a very small image still.
    Vray, Enscape, and iray (in Max) all run on GPU, which makes them render stupid fast, unless you have a completely lousy graphics card.
    December 3, 2012
    57
    02:51 AM
    Low resolutions like 1920x1600 is not high enough for Visualization. Those like I believe it was Fred's post, was that there are 3 types of rendering...if it wasn't Fred, then I credit to whomever it was. Having my background, dpi's like 150 to 400 are normal (like 6500x3500 pixels). This is for high end entourage, and large format printing. So renderings like Aaron pointed out, yes, Revit, grain came from a High setting, at 4 hours. Moving that mark from 10 to 16 increased the rendering time to 17 hours. Yikes. I have a dual xeon processor and a 2 gig Nvidia card. Its not that. Its the engine, which was the jist of this re-topic post. I will look into Vray again. I was on the beta, but couldn't get the lights to work. Watching videos, I think it might be I was lacking the IES files on the interior lights.
    I understand that Lumion and Enscape are live. Enscape is really impressive. The price tag on Lumion is a little daunting but in terms of ease of use, it seems very intuitive. I was asked to join on Lumions initial beta years back. I had to pass at the time unfortunately.
    10,127
    01:51 AM
    If you are using GPU rendering engines it doesn't matter (at all) what type of CPU you have. And if you are using GPU rendering a 2GB graphics card isn't that powerful.
    And if you aren't using a GPU rendering engine, yes... It's going to take forever without something like back burner or a dedicated node.
    Revits internal rendering engine isn't GPU enabled. Never has been.
    Aaron Maller
    Director
    Parallax Team, Inc.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    12:51 AM
    Thumbs up rendering
    I've never had slowness using both my Xeon cpu's 48 cores and both nvidia 3gb gpu cards I have. I can crank 4K renderings out on medium final gather and 2x settings in probably 10 minutes. The higher the poly-count, the longer it takes.
    Re-using final gather maps helps as long as the scene doesn't change significantly and a lot of people forget about "render region" to fix little issues here and there.
    I agree though 1080p has become the new "baseline" render instead of high end. I remember not that long ago we did a 720p resolution video back in 2010 and we thought that was the coolest thing we ever did.
    January 19, 2012
    325
    01:51 AM
    If you really want to find the best software, then just the Quality of the Rendering output itself lacks a proper measuring stick. After all, we are in a business/profession & economic principles matter to the CEO. A matrix of ROI from various aspects needs to be accounted for. How long is the period from training to efficiency in producing; Time it takes to prep a file for rendering; time it takes to output a rendering measured against time & quality; hardware needed & its cost to produce effectively; what's the cost of paying a user for the time it takes to produce the final outputs; & what's the cheapest investment per Prepping to Rendering time to Quality output ratios per image.
    The definition of the best may be different per firm based on meeting the talent/hardware/budget/time/quality/expectations on-hand. Today's Modern Art scene has no real quality measure of disciple (sad), but at least the path to get to quality rendering outputs do. Sometime it could be Max, or Lumion, or VRay, & or even Enscape. Sometimes the journey holds more value than the final outcome.
  1. 2017 Rendering - DPI setting is ignored?
    By cellersick in forum Rendering and Gallery
    Last Post: May 13th, 2019, 10:18 PM
  2. Rendering Colored Glass in Revit 2017
    By rteneb in forum Rendering and Gallery
    Last Post: July 17th, 2017, 03:49 PM
  3. Will Revit 2017 , allow me to design high qaulity conservatory's rendering?
    By duffy1807 in forum Architecture and General Revit Questions
    Last Post: October 30th, 2016, 06:26 PM
  4. Best rendering software for photo realistic renderings
    By Andrew P in forum Rendering and Gallery
    Last Post: December 2nd, 2015, 06:53 PM
  5. Practice Revit software or Revit software lab near Seattle
    By julietsketches in forum Architecture and General Revit Questions
    Last Post: June 27th, 2015, 06:17 AM
