Results 1 to 5 of 5
Thread: Noisy render
    June 13, 2017
    2
    12:29 PM
    Thumbs down Noisy render
    I want to make less noise on this render. My sun setting is interior sun and artificial. Sun time is 11:00am.
    Can't seem to find a reason for it unless I'm missing something obvious?
    October 14, 2011
    Boston, MA
    220
    06:29 AM
    Quote Originally Posted by danieltimms View Post
    what render quality or resolution do you have it set to?
    June 13, 2017
    2
    12:29 PM
    Quote Originally Posted by billiam View Post
    Its currently set to 'High' quality.
    December 20, 2010
    1,057
    07:29 AM
    What size is the crop region? adjust it(scale) to be larger. My guess is you have a very small image. Also what version of revit are you using? I have been told improvements have been made to the rendering engine that address this also in 2018 from 2016/17. But you have to increase the number of "levels to get rid of the grainy look.Noisy render-rendering-settings.jpg Note I'm not saying these settings will be perfect for you, but try going to 12 and try simplified vs percise.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    07:29 AM
    Quote Originally Posted by sdbrownaia View Post
    What size is the crop region? adjust it(scale) to be larger. My guess is you have a very small image. Also what version of revit are you using? ... But you have to increase the number of "levels to get rid of the grainy look.Click image for larger version.
Name:	Rendering settings.jpg
ID:	30670 Note I'm not saying these settings will be perfect for you, but try going to 12 and try simplified vs percise.
    +1 for using a larger image.
    I've been pretty happy with using a custom setting for renderings, using Advanced Textures & 10 passes. It produces a nice image but doesn't take forever to run.
  1. Batch Render
    By patdav44 in forum Architecture and General Revit Questions
    Last Post: May 3rd, 2015, 05:26 PM
  2. Cloud render compared to 3dsMaxDesign 2013 render (internal)
    By willsud in forum Rendering and Gallery
    Last Post: September 6th, 2013, 09:27 AM
  3. How to render ?
    By grandmaestro900 in forum Architecture and General Revit Questions
    Last Post: March 11th, 2013, 05:21 PM
  4. render time
    By sohn in forum Rendering and Gallery
    Last Post: September 24th, 2012, 08:08 AM
  5. Finish Render
    By andyl0193 in forum Architecture and General Revit Questions
    Last Post: May 24th, 2012, 06:27 AM
