Results 1 to 6 of 6
Thread: Issues with Rendered Glass Appearance (Revit 2017)
    New Member ckeenum82's Avatar
    January 18, 2015
    South Bend, Indiana
    3
    04:47 AM
    I am having an issue with glass appearance in a scene I'm renderings with Revit 2017 that I have not experienced with previous versions of the software.
    Within my interior scene, I have several light fixtures that use clear glass. When I render on a lower setting such as Medium 150 dpi, the glass appears clear as I would expect. However when I render on a higher setting such as High 300 dpi, the glass appears like a dark gray frosted material.
    I cannot seem to resolve this and I am looking for any possible solutions. Please see attached images for reference. Thank you!
    Attached Thumbnails Attached Thumbnails Issues with Rendered Glass Appearance (Revit 2017)-rv-interior-template-modern-3-medium-150dpi-.jpg   Issues with Rendered Glass Appearance (Revit 2017)-rv-interior-template-modern-3-300-dpi-.jpg
    December 21, 2010
    Phoenix, AZ
    2,599
    03:47 AM
    I'm going to guess it has something to do with the number of refractions the rendering calculates. Medium has fewer (or none), high has more.
    January 18, 2015
    South Bend, Indiana
    3
    04:47 AM
    In Revit 2014 I'd have hope to resolve this issue based on your reply. I recall that I could adjust reflection/refraction, however in 2017 - I don't have that capability as far as I know. I will continue to experiment. If I can find a solution, I will post. Thanks!
    December 21, 2010
    Phoenix, AZ
    2,599
    03:47 AM
    Hmmm... that's new. Sorry then. I got nothing.
    March 21, 2013
    Phoenix, AZ
    275
    03:47 AM
    Have you tried using an Appearance that is based off a Generic Appearance and manually configuring it to mimic glass? To me it's not readily apparent how the properties of the OOTB Glass appearance will affect the rendering.
    January 18, 2015
    South Bend, Indiana
    3
    04:47 AM
    I haven't yet - but I'm going to try it because this is driving me nuts!
  1. IFC Revit 2017 export issues
    By francescorevit in forum Architecture and General Revit Questions
    Last Post: October 9th, 2017, 10:52 AM
  2. Replies: 0
    Last Post: October 1st, 2016, 04:15 AM
  3. Interior Glass Parittion (Curtain Wall) - Mullion resize issues
    By revit_user in forum Architecture and General Revit Questions
    Last Post: April 30th, 2013, 06:33 PM
  4. Image map vs. rendered appearance
    By cellophane in forum Rendering and Gallery
    Last Post: October 7th, 2012, 04:21 PM
  5. Same glass material, different color appearance !!!
    Last Post: September 26th, 2012, 10:14 PM
