Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By willsud
Thread: Revit 2018 Interoparability with 3dsMax 2018 not available?
    December 13, 2010
    Ambleside, Lake District, UK
    936
    11:08 AM
    I wondered if anyone else has tried linking Revit 2018 files into 3dsMax 2018?
    When I try to link a Revit 2018 file into 3dsMax 2018 a message appears in 3ds Max saying that Revit Interoparability is not installed.
    FBX linking works OK and the Help file says that Revit linking should work, maybe just not yet
    I've looked at the installer for BDSP again and don't see anything extra available.
    (I know Revit linking wasn't very clever in 2017 versions but you live in hope )
    December 13, 2010
    936
    11:08 AM
    Interesting - I've had notification of an Autodesk Customer Support case by email re. this issue.
    Some kind person at Autodesk must have created it?
    December 13, 2010
    936
    11:08 AM
    Uninstalling and reinstalling both 3ds max 2018 and Revit 2018 hasn't made any difference - the Revit interoperability error message still appears when attempting to link a Revit 2018 file into 3dsMax 2018.
    It isn't worth bothering further with this - I'll stick to linking FBX exported from Revit, and the 2017 versions, as at least that works.
    December 13, 2010
    936
    11:08 AM
    Just to mention that a kind support person over on the Autodesk 'TheArea' Forum has sent me a link to download the Revit 2018 interoperability installer.
    Unfortunately I can't figure out how to make it install as it says to run Setup, and BDSP 2018 Setup doesn't seem to offer an opportunity to install anything outside the downloaded package.
    Hopefully they will advise later
    Nice that they are at least trying.
    Hirvio likes this.
    December 13, 2010
    936
    11:08 AM
    Credit where it's due, Autodesk Support on theArea forum have stuck with this and posted a link to the Virtual Agent to allow me to download just 3dsMax 2018 which then offers to install not just the Revit 2018 interoperability add-in but also the Arnold renderer which was missing from the BDSP 2018 install package (but there may be a newer version on the Arnold home site).
    This is the thread over there if anyone else has this issue:
    https://forums.autodesk.com/t5/3ds-m...ght/false#M391
    Junior Member Barry Mair's Avatar
    May 9, 2014
    Sydney, Australia
    12
    09:08 PM
    Hi William.
    Thank you for the solution. Happy.
    Barry.
  1. Revit 2018 template upgrade failure
    By brane1012 in forum MEP - General
    Last Post: June 30th, 2017, 06:01 PM
  2. 2018 - What's New webinar April 18
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 6th, 2017, 10:13 PM
  3. Revit 2018 Wish List
    By Robin Deurloo in forum Architecture and General Revit Questions
    Last Post: March 26th, 2017, 09:25 PM
  4. What Revit Wants: Autodesk 2018 Direct Download Links
    By luke.johnson in forum Blog Feeds
    Last Post: March 22nd, 2017, 01:15 PM
  5. Replies: 0
    Last Post: March 21st, 2017, 10:45 AM
