Results 1 to 6 of 6
Like Tree9Likes
  • 10 Post By sdbrownaia
Thread: water falls
    April 5, 2017
    4
    08:01 AM
    water falls
    can anyone suggest how can i put water on the waterfalls rocks thanks
    December 20, 2010
    1,077
    08:01 PM
    Yes, use a swept blend shape with a water material that looks like a water in section, basically wavey shape as tight or rough as you want. Then use a revolve or sweep for the ripples where it hits the water. Yes this image is 100% revit.water falls-waterfalls.jpg
    Gold Coast
    2,641
    10:01 AM
    Quote Originally Posted by sdbrownaia View Post
    Yes, use a swept blend shape with a water material that looks like a water in section, basically wavey shape as tight or rough as you want. Then use a revolve or sweep for the ripples where it hits the water. Yes this image is 100% revit.Click image for larger version.
    That looks great Scott.
    You could also create sweeping forms in the massing environment.
    December 20, 2010
    1,077
    08:01 PM
    For a rougher water fall look I've taken imagery from a waterfall, messed with it in PS so its seamless then used it as a material.
    August 23, 2018
    1
    12:01 AM
    Water fountain
    Do you mind sending me the water fountain? I'm not succeeding in making the sweep blend.
    thanks
    December 20, 2010
    1,077
    08:01 PM
    wall fountain
    Here is the family, its quite old but you'll see how I did it.
    Attached Files Attached Files
  1. Roof issues- roofline level falls
    By ebalinska in forum Architecture and General Revit Questions
    Last Post: June 27th, 2016, 09:32 AM
  2. Water?
    By Lox in forum Architecture and General Revit Questions
    Last Post: August 7th, 2014, 03:05 AM
  3. how to make falls ceiling with revit pleas ?
    By Mena__99 in forum Architecture - Family Creation
    Last Post: March 26th, 2014, 08:50 AM
  4. Falls in ground slab - Why is this not possible?
    By JasonWallis in forum Structure - General Questions
    Last Post: February 18th, 2012, 12:08 AM
  5. Water
    By assem in forum Rendering and Gallery
    Last Post: October 19th, 2011, 08:10 PM
