Results 1 to 7 of 7
Thread: More realistic rendering?
    October 25, 2016
    1
    06:18 PM
    Hello, producing this rendering but not satisified at it. (still using revit 2008 to modelled and render). how can i make it look more realistic? is it the programs i am using is too old? .. thanks for help and suggestions.
    Attached Thumbnails Attached Thumbnails More realistic rendering?-3d-view-2-zoom.jpg   More realistic rendering?-3d-view-2.jpg
    Coeur d Alene, ID
    4,815
    04:18 AM
    Using an 8 year old program....that could be a reason..
    Or...use something other than Revit if you wan't perfection. Nothing wrong with exporting to another program like Max or a third party program.
    March 21, 2013
    Phoenix, AZ
    275
    04:18 AM
    It's not necessarily about the age of the program. 3ds Max 2008 would give you more potential to make the scene more realistic. I believe Revit's rendering limitations are a conscious decision to hide all the "rendering nastiness", as photorealistic rendering can become truly daunting.
    There's plenty of tutorials online if you want to go down that rabbit hole
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    05:18 AM
    Even upgrading to Revit 2012 would result in a better image. Photoshop will be your friend otherwise.
    December 20, 2010
    1,071
    07:18 AM
    I think 2008 had Mental ray, if so, upgrading to 2012 wouldn't do anything. Something looks really odd about his materials. Like its a shaded view, not real world materials or he is just using colors and not image maps and custom materials. I suspect upgrading alone will do you no good. You need to swap out your materials for some image based materials.
    August 15, 2012
    USA
    191
    05:18 AM
    I remember 2008. <shudders> It had Accurender. only. The unholy offspring of a potato shredder and an Apple II.
    Revit : Rendering in Revit Architecture 2009 This was the greatest day of April of 2008 for me when it released.
    Its honestly not THAT bad of a rendering should you put a little time in photoshop to adjust the levels, HDRI that puppy and play with the colors and contrast.
    February 25, 2017
    2
    11:18 AM
    Upgrade to 2009
    You should probably upgrade to Revit 2009 ,if you want to stick with the old GUI , there is some significant improvement with the rendering,
    here two examples done with Revit 2009, no photoshop, basic material, basic lightning, medium setting,
    if You want, you send me the project, then I hit render with Revit 2009 to see what come out,
    If the project can be share,
    could miss some texture,soo
    cheers,
    Attached Thumbnails Attached Thumbnails More realistic rendering?-1.jpg   More realistic rendering?-3d-view-212.jpg
  1. how to make more realistic?
    By haydenrrr in forum Rendering and Gallery
    Last Post: August 25th, 2016, 01:42 PM
  2. Section box - how to get realistic shadows when rendering?
    By emilsod in forum Architecture and General Revit Questions
    Last Post: January 8th, 2016, 12:36 PM
  3. Best rendering software for photo realistic renderings
    By Andrew P in forum Rendering and Gallery
    Last Post: December 2nd, 2015, 06:53 PM
  4. Rendering Realistic Rocks
    By Versiamo01 in forum Architecture and General Revit Questions
    Last Post: November 18th, 2014, 05:28 PM
  5. making realistic RPC like shaded in realistic mode???
    Last Post: April 20th, 2012, 06:30 AM
