Results 1 to 6 of 6
Thread: how to make more realistic?
    November 30, 2015
    15
    01:01 PM
    hi guys, im producing this rendering but am not satisified at it. (using revit to render). how can i make it look more realistic? is it the programs i am using? any tips and tricks to improve this such as lighting landscaping etc. the roof is supposed to be a corrugated sheet same color as the darker roller door but doesnt seem to change color even though they are the same material.. any help on all these questions would be greatly appreciated!!
    Attached Thumbnails Attached Thumbnails how to make more realistic?-3d-view-3.jpg
    July 7, 2011
    Rotterdam, Holland
    1,249
    05:31 AM
    Think you are lacking some textures for your roof and maybe other materials. Driveway looks like it is plain concrete (and a very white one too). Glass has no reflection that I can see.
    Trying rendering myself too, so I know you will run into some problems, but in the end you should be able to get a better looking image for sure.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    09:31 PM
    Every tried combining 3dsMax + Revit?
    Mistress of the Dorkness: Revit + 3dsMax: Utilizing Render Techniques - A Winning Combination
    Materials are important.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    11:31 PM
    Materials and little details count when going for realism. Here are some helpful links of posts I have published over the years:
    Rendering Tip - A Simple Material Change to Add Realism | TheRevitKid.com! - Tutorials, Tips, Products, and Information on all things Revit / BIM
    This is a link to all of the posts talking about materials and Revit:
    materials | TheRevitKid.com! - Tutorials, Tips, Products, and Information on all things Revit / BIM
    Cheers and good luck!
    December 20, 2010
    1,061
    10:31 PM
    Rendering is all about Materials, Lighting and angle. This is not my best work but its a similar type of project. So hopefully it will help you. These are 100% rendered in revit(5 years ago or so). The only thing done in Photoshop is to add the lake in the back. The people and trees are all RPC content. You can see taking care in your roadway material and little details like adding stripes to the road, mulched areas around the planting. Light posts, etc. all add to the realism. Roofs are hard because roof tiles are repetative. you can spend time in photoshop creating a better pattern, but i used what I got off the MFR website. Learn the material editor, use image based materials not the procedural.how to make more realistic?-rendering.jpghow to make more realistic?-rendering-2.jpg
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    11:31 PM
    Quote Originally Posted by sdbrownaia View Post
    Rendering is all about Materials, Lighting and angle. ...You can see taking care in your roadway material and little details like adding stripes to the road, mulched areas around the planting. Light posts, etc. all add to the realism.
    Even with mediocre materials the little details like striping & curbs will make the image infinitely better. I'll try to find some samples I have later today to share
  1. Photo Realistic platforms
    By mikeybluet in forum Architecture and General Revit Questions
    Last Post: March 12th, 2016, 03:17 AM
  2. Realistic renderings?
    By lolcocks in forum Rendering and Gallery
    Last Post: January 6th, 2016, 02:56 PM
  3. Realistic graphic overide.
    By darkwing in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2013, 03:03 PM
  4. Realistic Visual style
    By anjali in forum Architecture and General Revit Questions
    Last Post: April 12th, 2013, 08:00 AM
  5. making realistic RPC like shaded in realistic mode???
    Last Post: April 20th, 2012, 06:30 AM
