Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: My First Animation
    June 27, 2016
    1
    04:25 PM
    My First Animation
    Give me some advices
    https://youtu.be/M0rAm0q_ES0
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:25 PM
    Feels a bit like a roller coaster to be honest and your resolution at 480 is WAY to low in this day and age.
    10,036
    11:25 AM
    Yep. Moves WAY too fast. Also, too much movement, even if its slower. If you need to pan this way and that to see different things, cut to a different animation path, and splice them to gether with a GENTLE fade here and there. I also wouldnt have the path plow through the entourage people.
    December 21, 2010
    C.LONDON
    4,353
    05:25 PM
    Quote Originally Posted by cylee560 View Post
    Sorry, you get a welcome first!
    Now to the advice...
    If you can up the resolution, even to boggo-720, without crippling your bake times then that'd be nice.
    (let's be fair Robin, the opening splash in the vid. suggests our OP is a uni. student) - if you've nothing of the sort already, look into virtualdub for (free) post-processing - it's got tons of addins to handle frame doubling, dithering, etc...
    I'll second Aaron's critique - but won't repeat it - instead get yourself onto Ronen Bekerman - 3D Architectural Visualization & Rendering Blog and watch how some of the visual pro's "shoot" their videos - using cinematography devices (stills, pans, dollies, DOF, etc) to tell stories of the scenes - rather than rehash the hackneyed ubiquitous "walkthrough-on-rails" attempts by (most) architects.
    Oh and simply because I've not posted it anywhere in at least a month...
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:25 PM
    Oh I guess I forgot to welcome you on the forum too, so Welcome!
    A uni. student indeed I guess, but that does not make a 480 resolution any better. That said I have never made any animation in my life, so just commenting on what I see.
    January 17, 2011
    1,982
    11:25 AM
    Way better than I can do on a first try in 3dsMax. Good job. Find some good walkthroughs and copy them to learn. Like they say, imitation is the sincerest form of flattery. It also will spawn new ideas for you to take things down your own path.
    FWIW, there is a lot of specialty software available now that specializes in this and does so very easily and effectively.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:25 PM
    Is that all CG?! (didn't have audio on...) It's spectacular if it is.
    December 21, 2010
    C.LONDON
    4,353
    05:25 PM
    Is that all CG?!
    Yup. There are segments towards the end that deliberately "expose" where/how it's not camera work. More here: Customer Success Story :: Silestone and The Third and The Seventh projects & here Alex Roman interview: The Third & The Seventh, From Bits To The Lens book
    cellophane likes this.
    Member gru3d's Avatar
    March 2, 2016
    58
    04:25 PM
    I think the thing that can be somewhat criticized is that it changes direction way too fast, but I believe it's an issue of revit itself. Quite tricky adjusting cameras direction.
    Also, is very good to combine different speeds along the presentation, so is less monotonous. Sometimes, look to one side and another while you are walking is good because provides less sense of claustrophobia. Just think that when you are walking in a straight line some people may want to look to the sides to see what's there (to see if there's someone else for example). Weird but I like it.
    September 5, 2013
    13
    09:25 AM
    The third and the seventh, inspiration for all
    - - - Updated - - -
  1. Replies: 0
    Last Post: March 6th, 2015, 01:15 AM
  2. Create an animation - 3DS Max or Navis?
    By MartinGT in forum Coordination Tools
    Last Post: May 25th, 2014, 06:17 AM
  3. Automated Animation from Revit
    By cbaze in forum Architecture and General Revit Questions
    Last Post: June 30th, 2011, 12:42 PM
