Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By willsud
  • 1 Post By rbcameron1
Thread: SP2 for 3dsMax2016 loses Arch&Design Materials - fix available
    December 13, 2010
    Ambleside, Lake District, UK
    951
    06:15 PM
    I've been puzzled that my linked Revit 2016 models into 3dsMax2016 could no longer have Arch&Design glass, or any other A&D material swapped in for Revit glass, or other material.
    In fact the A&D materials would not appear on objects created from scratch in 3dsMax.
    After much fruitless reinstalling and investigating paths (which was educational, if frustrating) this thread in the Area forum (where I guess I should have headed straight away ) points the finger at SP2 for 3dsMax 2016 - with or without the extension pack.
    There is a script provided which fixes the problem (but read the thread if you are affected as version 3 is the one you want, down the list of posts):
    Arch and Design templates not working anymore and errors - Page 2 - Autodesk Community
    cellophane likes this.
    December 13, 2010
    951
    06:15 PM
    Sorry, I'm behind the times - SP3 is out and fixes the Arch&Design Materials problem :
    https://knowledge.autodesk.com/suppo...-3.html?v=2016
    /later:
    the kind person who posted the script fix tells me that the v3 script checks for SP3 installed and notifies the user that it is not needed if SP3 already installed.
    Cool
    Last edited by willsud; March 2nd, 2016 at 01:06 PM. Reason: additional information
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    11:15 AM
    Even after the 3 SP's and 2 Ext.Packs I still can not get Revit 2016 and Max 2016 to talk to each other. This worked perfectly in 2014 and 2015, now it's broke beyond repair? Seems ridiculous.
    willsud likes this.
  1. Problems updating linked Revit2016 into 3dsMax2016?
    By willsud in forum Rendering and Gallery
    Last Post: October 9th, 2018, 02:39 PM
  2. Keynote legend loses formatting when put on a new sheet (Revit 2015)
    By pgibby in forum Architecture and General Revit Questions
    Last Post: February 19th, 2016, 03:08 PM
  3. Using Arch 2d DWG files (from vectorworks) as RVT backgrounds for Structural Design?
    By ecraider in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 07:06 PM
  4. Design Options + Materials
    Last Post: October 12th, 2011, 09:08 AM
  5. Ugrading from Revit Arch Suite to Bldg Design Suite?
    Last Post: June 16th, 2011, 08:17 PM
