Results 1 to 4 of 4
Thread: Cloud Rendering Error
    September 26, 2011
    119
    08:17 AM
    this can lead to all different reason or no answer
    in Cloud Rendering
    When you get a error pop up" A Problem occurred. The Rendering Service Could Not Complete your Request."
    what would be the most typical reason for getting this pop up?
    can this be something to do with autodesk server? I am getting this since last friday.
    Member BD Mackey's Avatar
    November 1, 2013
    466
    10:17 AM
    I have not seen this error so I can't really help but Autodesk does have a check on most of thier cloud services. Unfortunately rendering isn't one of them but I still go here when having issues to see if any of theiir services are degraded. As of now nothing is down so maybe an issue with your connection or file
    https://health.autodesk.com/
    jmk
    jmk is online now
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    10:17 AM
    Check your view name. A coworker had this issue with commas in a view name, and I suspect any characters you can't use in a typical windows file name would also cause the error. There are a couple more possibilities here: Frequently Asked Questions - Autodesk Community
    February 26, 2019
    1
    08:17 AM
    I get this notification all the time, I find it often happens after the file gets too big or I import too many of my own materials. Several times I have been able to save the file by using "purge unused". However the file I am currently working on is not responding to that command so I do not know what to do Anyone have any recent incite??
  1. Urgent!! 2 rendering cloud error ...help
    By dadin in forum Architecture and General Revit Questions
    Last Post: May 14th, 2015, 04:00 PM
  2. RPC's and Cloud Rendering
    Last Post: May 20th, 2014, 08:00 PM
  3. Revit Cloud Rendering
    By patdav44 in forum Architecture and General Revit Questions
    Last Post: February 6th, 2014, 09:01 PM
  4. Replies: 0
    Last Post: August 17th, 2013, 06:15 AM
  5. Revit Kid: Cloud Rendering... Use your 25!
    By The Revit Kid in forum Blog Feeds
    Last Post: December 22nd, 2011, 02:45 PM
