Results 1 to 4 of 4
Thread: Black walls in rendering
    February 1, 2016
    2
    05:22 PM
    Please help! I'm rendering the pavilion in the cloud and although all the wall materials are the same (some material which I created my image), on some of the walls it appears totally black without any texture. I checked all the light settings and it's not becasue of that...
    Attached Thumbnails Attached Thumbnails Black walls in rendering-local_model_-_joanna_1_february.rvt_2016-feb-01_02-32-22pm-000_visu1-1-.jpg
    December 21, 2010
    C.LONDON
    4,353
    05:22 PM
    When you say the materials are the same, do you mean the walls that are rendering black are the same type as those that aren't?
    I ask because you flag two (related) possible causes; one you're using the cloud render, two you've created your own material. Why? The Cloud renderer, IIRC, doesn't much care for custom-made materials (meaning materials using image files saved on your computer/network aren't accessible).
    But that's only the "obvious" answer if the ones that are rendering black are exactly the same as the ones that aren't rendering correctly with the hexagonal pattern.
    Question is, how does it render using the native Revit rendering engine? (throw a quick draft test at it, no need to waste your time with a high quality one)
    And welcome to the forum!
    February 1, 2016
    2
    05:22 PM
    Hey yes all the walls have the same material which I created by image... Can I somehow make this image "more accesible" for the cloud? In normal rendering in revit its not black but the quality is a disaster even if i put 300px
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    12:22 PM
    Quote Originally Posted by joalem View Post
    can you show us a screen shot of the material editor for those materials?
  1. New arch client, walls/roofs cut as solid black or outline only
    By phoulx in forum Structure - General Questions
    Last Post: April 24th, 2014, 03:21 PM
  2. Replies: 0
    Last Post: August 28th, 2013, 07:15 PM
  3. Black screen after rendering a few times
    By amyflipflops in forum Rendering and Gallery
    Last Post: April 8th, 2013, 10:48 AM
  4. Revit 2013 - rendering within Revit - black screen first
    By willsud in forum Rendering and Gallery
    Last Post: August 18th, 2012, 12:05 AM
  5. Revit 2011 - "Black rendering" with Non-English Win XP
    By Munkholm in forum Tutorials, Tips & Tricks
    Last Post: January 10th, 2011, 09:15 AM
