Results 1 to 4 of 4
Thread: All of my walls are transparent?
    Junior Member jeeenyuss's Avatar
    February 17, 2014
    St. Louis, MO
    30
    11:38 PM
    I'm trying to create a rendering of a room in order to showcase to a client what it will look like, but all of the walls, ceilings, and floors are transparent. I have been in visibility graphics and transparency is at 0 in everything. I've tried overriding graphics in view in order to make them not transparent and it's the same issue. Any suggestions? Thanks.
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    10:38 PM
    If you are rendering you need to check the material appearance, not the visibility graphics. If everything has a <By Category> for the material check in the object styles and modify the material assigned. I know a lot of the default mass materials have a transparency.
    February 17, 2014
    St. Louis, MO
    30
    11:38 PM
    You can't do that if it's a Linked model, right?
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,415
    10:38 PM
    Quote Originally Posted by jeeenyuss View Post
    If the linked model has been assigned a category you'd need to change it there.
  1. Transparent 3D line
    By ohmygod in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2015, 04:03 PM
  2. Transparent .pdf backgrounds
    Last Post: February 27th, 2014, 05:44 PM
  3. Not so transparent
    By Vanguard in forum Structure - General Questions
    Last Post: March 31st, 2011, 07:39 AM
  4. Transparent Glass not transparent in Section View
    By Elisa in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 06:02 PM
  5. 2D Transparent Glass
    By mark b in forum Architecture - Family Creation
    Last Post: December 15th, 2010, 08:15 PM
