Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By sdbrownaia
Thread: Rendering problem - Not enough memory
    December 14, 2015
    2
    04:58 PM
    Hi all,I bought few weeks ago the workstation Dell Precision M4800 (Windows 8.1 Pro, processor Intel Core TM i7-4710MQ, 16GB RAM) and I'm trying to render a Revit project using Revit Architecture 2015. The project is a central file of 42MB with 8 linked files of 18MB, 72MB, 41MB, 47MB and (4x) 5MB. After 10 hours of rendering with no feedback and with the rendering progress stuck to 10% I've got a message saying that I don't have enough memory to render the image. Is that normal? I mean, the file is quite big but not enormous I think and the workstation is new as well so I can't figure out what's going on.
    Could someone help me please? I would really appreciate any suggestions. I've searched on the forum if there was a similar post but I haven't found anything like that so hope to have some feedback which will be used by future users as well.
    Many thanks
    December 20, 2010
    1,045
    12:58 PM
    Its probably what settings you used and how large your view is. Its critical you put the settings correct. You can't just pick a camera view, make the crop 24 x 36 and set the render settings to best and 300 dpi. Especially if its a night shot. So lets back up and review the settings you have, then you should be able to render your model better then you expect in less time you expect.
    1. Set your view port / crop size to the final size you want to print your image. Ie 6 x 9, 11 x 17, 24 x 36, etc.
    2. Set your rendering settings. Take the "draft" and click edit, then click copy to custom and make the first slider(anti-aliasing) set to 6, then scroll down and set the Soft Shadows to a value of 2
    3. Set the dpi. Start with 72, check your image and if you like it, then run it higher. typically you wont need more than 150. With each increase in dpi, you'll see the size of the image change and its an exponential increase in size and time to render.
    4. If you are doing an interior shot or night shot with lights you need to put your lights on light groups, you can't just render with all the lights on, each light adds significantly to rendering time. So you want to limit the lights you actually need on.
    5. render away.
    cellophane and Ning Zhou like this.
    December 14, 2015
    2
    04:58 PM
    Many thanks sdbrownaia for your reply. I'll try to render the image again and see how it goes. Thanks again, g
  1. New and very odd rendering problem
    By sdbrownaia in forum Rendering and Gallery
    Last Post: June 30th, 2015, 10:35 AM
  2. rendering problem
    By ragip in forum Architecture and General Revit Questions
    Last Post: September 13th, 2013, 10:39 PM
  3. Have a problem while rendering
    By suresh1622 in forum Rendering and Gallery
    Last Post: February 19th, 2013, 03:11 PM
  4. Rendering Problem
    By Tom Dolle in forum Rendering and Gallery
    Last Post: May 9th, 2012, 08:33 PM
