Results 1 to 2 of 2
Thread: rendering skips to 100%
    June 6, 2014
    10
    10:41 PM
    Exclamation rendering skips to 100%
    When doing renderings suddenly this has started to happen. it will go like usual for 10-60 seconds and then just skip to 100 as if I hit cancel. Anyone seen this before?
    revit 2015 update 9
    cpu- fx 8350
    psu- Corsair ax860
    mobo- Asrock 990fx extreme 4
    thanks
    St. Louis, MO
    1,954
    09:41 PM
    Test another project, and see if it happens. If so, it could be a hardware problem.
    If not, it could be something in your 1st project--triple check render settings, etc.
  1. Rendering 101 - Help
    By mrchumney in forum Rendering and Gallery
    Last Post: October 15th, 2014, 01:38 PM
  2. only 1 CPU for rendering
    By popluhv in forum Rendering and Gallery
    Last Post: May 14th, 2014, 02:45 PM
  3. Replies: 0
    Last Post: August 17th, 2013, 06:15 AM
  4. First Rendering
    By luiszavarq in forum Rendering and Gallery
    Last Post: April 2nd, 2013, 09:24 PM
  5. Rendering
    By derio in forum Rendering and Gallery
    Last Post: August 14th, 2012, 04:45 PM
