Results 1 to 2 of 2
Thread: Paint Materials Testing - Light Spots
    December 20, 2010
    1,036
    08:29 AM
    I've been doing some testing to determing what affects light mold and specular light dots. These are Interior Artificial lights only. this test is using the custom "quick" interior settings where I'm only taking the Draft and adjusting the anti aliasing to 6. So these could be improved potentially by bumping up various settings. I'll post the images when I'm done, but in first pass if you want to avoid specular spots, use Flat paint.
    1. Flat Paint works great, no speckles (can be roller, spray or brush)
    2. Eggshell - Causes specular spots (separated) regardless of application.
    3. Platinum - Causes Specular Spots ( lots of them sim to Pearl)
    4. Pearl - Causes specular Spots(very close together in oval shapes)
    Member JeffreyMcGrew's Avatar
    December 10, 2010
    Oakland, ca
    294
    05:29 AM
    Flat materials render faster as well.
    Reflecting materials, esp. blurry reflections, take the longest.
    To see this first-hand try this: take a normal interior scene, add a standard wood floor that's got blurry reflections. Render. Now switch it to be flat, no reflection in the floor, and see the render time plummet!
    Mental Ray seems to really slow down with certain materials!
  1. 2012 - Parametric Paint option broken ?
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: July 12th, 2012, 02:40 PM
  2. Paint tool
    By Advent in forum Architecture and General Revit Questions
    Last Post: May 14th, 2011, 12:42 PM
  3. Testing attachments
    By Munkholm in forum Forum Suggestions and Feedback
    Last Post: December 10th, 2010, 10:03 PM
  4. Cheers (Testing smileys)
    Last Post: December 8th, 2010, 06:47 PM
