Results 1 to 7 of 7
Thread: Having trouble getting Revit texture map to align with its bump map
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    03:36 AM
    I'm having some material alignment issues, and was wondering if anyone else has had the same. I was attempting to create a travertine floor, so I took an existing Stone material, duplicated it, duplicated the Appearance Asset and added my own texture map, I checked the Bump map and added a map that I know perfectly aligns in Photoshop (and actually, I get the same result if I use the same map for texture and bump)
    Anyways, It doesn't align in the X-direction, and using the position offset doesn't really help either. I've attached a few images and even the maps if someone wants to try it. the maps are scaled to be 6m wide by 3m tall.
    Any suggestions? I'm really liking the cloud render, and don't want to have to export to 3ds Max. I'm using Revit 2015 R2.
    Thanks,
    Ryan
    Images:
    Floor with texture and bump
    Floor with texture only
    Texture editor for surface map
    Texture editor for bump map
    Texture map
    Bump map
    Attached Thumbnails Attached Thumbnails Having trouble getting Revit  texture map to align with its bump map-travertine_w_bump.png   Having trouble getting Revit  texture map to align with its bump map-travertine_no_bump.png   Having trouble getting Revit  texture map to align with its bump map-travertine_texture_editor.png   Having trouble getting Revit  texture map to align with its bump map-travertine_bump_texture_editor.png   Having trouble getting Revit  texture map to align with its bump map-travertine1x1.jpg
    Having trouble getting Revit  texture map to align with its bump map-travertine1x1_bump.jpg
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    06:36 AM
    Quote Originally Posted by ryntau View Post
    Thanks,
    Ryan
    Images:
    Texture map
    Bump map
    Check in the "Graphics" tab under "Alignment" and "Texture Alignment".... Maybe that was set and something funky is happening with the bump?
    Does the bump look like it lines up in the render preview within the materials editor?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    06:36 AM
    Give "link texture transforms" a try as well. Don't know if it will solve it but you never know.
    October 11, 2012
    St. Louis
    403
    03:36 AM
    Quote Originally Posted by TheRevitKid View Post
    I think that Alignment in the Graphics tab is the texture map aligned to the Surface pattern, not the bump map. Regardless, it looks pretty good.
    I can't really see the render preview too well, is there way to expand the image to be bigger? with the slight offset of the bump, it's hard to tell on such a small image. My problem isn't really a huge issue, it just makes it a little ghosted, but i'd like to get it perfect.
    Are you guys able to recreate the problem with the maps I attached earlier?
    August 9, 2011
    Louisville, KY
    6,140
    06:36 AM
    I'm seeing the same behavior... I also recreated the bump by taking your image and desaturating just to make sure that the bump wasn't shifted in some way.
    I would try to find another material image and work from that. I've had good luck with this site: [CG Textures] - Textures for 3D, graphic design and Photoshop! and it looks like there are quite a few that would be very close to what you already have.
    May 22, 2012
    Connecticut
    185
    06:36 AM
    Well that is really weird... same thing here...
    I have made hundreds of bump maps from images in my time... First time I have ever seen this behavior... Not sure where you do the image but I think it is cursed...
    December 20, 2010
    1,057
    06:36 AM
    Have you tried mirroring the image and recreating the bump and starting from a generic material? Just to see if its some sort of issue with the material itself.
  1. Having trouble getting Revit material to align with its bump map
    By ryntau in forum Architecture and General Revit Questions
    Last Post: April 7th, 2015, 02:08 PM
  2. Revit 2014: texture editor with map channel and UV scale
    By rpict in forum Architecture and General Revit Questions
    Last Post: October 21st, 2013, 10:37 AM
  3. Just a bump for job opportunity
    By MPwuzhere in forum Out There
    Last Post: November 12th, 2012, 09:22 PM
  4. Bump: help needed
    By jbenoit44 in forum Rendering and Gallery
    Last Post: March 16th, 2011, 09:29 PM
  5. Re: rendering + bump map + relief + metal surface
    By jonathanlarocca in forum Rendering and Gallery
    Last Post: January 7th, 2011, 09:26 PM
