Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree8Likes
Thread: New and very odd rendering problem
  1. #11
    December 20, 2010
    1,071
    01:53 PM
    Yes, 100% revit, Yes I use both the real lights and then a couple studio lights(invisible round lights) that light up the ceiling. No photoshop, don't even have it on my machine anymore.
    pksimon2007 likes this.
  2. #12
    December 20, 2010
    1,071
    01:53 PM
    The key to good renderings in revit is understanding how to make good materials, set your light levels and time of day. The mental ray engine has been good for me. Don't rely on the OOTB materials, make your own, test render them, repeat. Note for the settings, don't ever use the OOTB settings, take your Draft setting, click the copy to custom button, set antilaising to 6 or 7 and enable soft shadows and set to 2. Leave the rest alone and for most renderings they will be fast and good looking.
    cellophane likes this.
  3. #13
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,189
    01:53 PM
    Quote Originally Posted by sdbrownaia View Post
    Do you use Gimp or something else to modify / tweak your material maps?
  4. #14
    10,356
    12:53 PM
    I suspect something in the *in-session* lighting settings. They dont travel from machine to machine...
  5. #15
    December 20, 2010
    1,071
    01:53 PM
    Paint .net is what is installed on my machine. I could do a lot better with photoshop I know. I miss it. But there is a seamless texture plug in I use for paint .net that helps alot. but I do miss some photoshop tools. We have a graphic's station with photoshop, so if I can't do what I need to with paint.net I can log into it. But I rarely do. Even the archvision plug in works with paint.net so I'm a happy camper.
    randallsstevens and Alex Page like this.
  6. #16
    August 9, 2011
    Louisville, KY
    6,189
    01:53 PM
    which seamless texture plugin do you use?
  7. #17
    December 20, 2010
    1,071
    01:53 PM
    Its called Seamless Texture Maker. It helps you get there a little quicker. I don't use the top choice, typically the Normal+Cut Blend Average. or the bottom one. See attached image. New and very odd rendering problem-seamless.png
  8. #18
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    850
    03:53 AM
    That first image looks looks like an arson squad investigation shot.
  1. rendering problem
    By ragip in forum Architecture and General Revit Questions
    Last Post: September 13th, 2013, 10:39 PM
  2. Wall Rendering Problem
    By nlr in forum Rendering and Gallery
    Last Post: April 19th, 2013, 08:31 AM
  3. Have a problem while rendering
    By suresh1622 in forum Rendering and Gallery
    Last Post: February 19th, 2013, 02:11 PM
  4. Problem Nvidia rendering
    By honestvip in forum Hardware and Infrastructure
    Last Post: January 30th, 2013, 04:20 PM
  5. Rendering Problem
    By Tom Dolle in forum Rendering and Gallery
    Last Post: May 9th, 2012, 08:33 PM
