Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By snowyweston
  • 1 Post By TheRevitKid
Thread: Interior Rendering w/ Mirror
    January 21, 2015
    6
    08:39 PM
    I'm often making renderings of small interior spaces (namely bathrooms) and in order to get a decent view of the room showing everything I have to put the camera outside and hide the walls blocking the view. This works fine some of the time, but the problem arises when I'm looking at a mirror and it reflects the hidden wall and shows just the sky background, which looks pretty ugly.
    Does anyone have any tips or methods for fixing this? The only thing I can think of is doing it like I would take pictures of a small room in real life, just taking multiple renders from the same spot and stitching them together in photoshop to get a view of the whole space.
    Thanks!
    Member BD Mackey's Avatar
    November 1, 2013
    468
    02:39 PM
    You could render once with the wall on, then use that render as a decal to put on the mirror, maybe take the render from the mirror looking at the wall? Just a thought haven't tried this theory.
    jmk
    jmk is online now
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,423
    02:39 PM
    Depending on what you need in the end you can render it as a panoramic too, then you can spin around in the center of the room.
    Coeur d Alene, ID
    4,783
    01:39 PM
    You can use the section box instead of using hide....unless that is how you are doing it..
    January 21, 2015
    6
    08:39 PM
    ^ That's a good tip but doesn't solve the problem.
    I think I'm going to try mirroring everything behind the mirror and make the mirror clear. We'll see how that works.
    December 21, 2010
    C.LONDON
    4,382
    09:39 PM
    You're adjusting your focal length yes?
    January 21, 2015
    6
    08:39 PM
    I didn't think that was possible in Revit.
    December 21, 2010
    C.LONDON
    4,382
    09:39 PM
    Quote Originally Posted by AmbientDesign View Post
    It's a "hidden" feature. Right Click your steering wheel...
    Raff likes this.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    04:39 PM
    Shout out to Snowy!
    Revit Tip - Increase / Decrease Focal Length of Camera | TheRevitKid.com! - Tutorials, Tips, Products, and Information on all things Revit / BIM
    The interesting thing about this "hidden" feature is many people don't even use the steering wheel! Talk about SUPER hidden feature.
    Raff likes this.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    03:39 PM
    Another "hidden" feature on the Steering Wheel is Rewind.
    Super-handy - especially when spinning around in 3D.
    It's kind of like Undo, but for just the Zoom and Pan commands.
    If you go too far and get lost, you can just fire up the Steering Wheel and hit Rewind.
    Then you'll get a filmstrip of all of the View changes you've made recently. Just move your mouse to the left to scroll back through your "history."
    Now, if they'd only make a Keyboard Shortcut for it...
  1. Sun Light in Interior Rendering
    By theshell07 in forum Rendering and Gallery
    Last Post: January 19th, 2016, 09:22 AM
  2. Interior light rendering
    By ChrisInTexas in forum MEP - General
    Last Post: March 4th, 2014, 12:40 PM
  3. Interior Rendering Performance
    By cwetzel in forum Rendering and Gallery
    Last Post: June 7th, 2012, 06:29 PM
  4. My First interior rendering Kitchen
    By ahmed_hassan in forum Rendering and Gallery
    Last Post: January 27th, 2012, 04:06 PM
