Results 1 to 1 of 1
Thread: Rendering settings revert on save/sync
    jmk
    jmk is online now
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    10:45 AM
    Artificial Lights resets when Rendering Settings is Closed
    I'm working on a project that has multiple areas, and after some trial and error got a workflow for setting up renderings that worked fairly well (Apply a view template to the view to set features, remove the template and adjust the lighting settings in the rendering settings dialog) I did the initial views and settings several months ago, and they still work fine. I've now added several more views and a light group for a different area.
    On the new views all the lighting properties reset to exterior, sun only on save. On older views, where I'm trying to turn off the new lighting groups, they also revert when syncing or saving.
    Any solutions?/reasons for why this might be happening?
    Edit: With further experimentation I have found that I can set the render scheme and the sun settings as long as I exit the Rendering Settings dialog between each change. I can not control lights via the Artificial Lights dialog at all. Turning lights/light groups off, dimming lights, moving lights to a group - all of it resets as soon as I exit the Rendering Settings dialog. In a view created previously that has lights dimmed any changes will reset, but the existing dimming is maintained.
    Last edited by jmk; January 30th, 2015 at 06:46 PM. Reason: More experimentation narrowed issue down
  1. Flipped curtain panels revert after reloading
    By woodhouse in forum Architecture and General Revit Questions
    Last Post: October 21st, 2014, 11:56 PM
  2. System type settings & Fan onnectors settings
    By Dogma in forum MEP - Family Creation
    Last Post: June 23rd, 2014, 11:42 AM
  3. Revert crop rotation to original view orientation
    By CADiva in forum Architecture and General Revit Questions
    Last Post: November 15th, 2013, 09:01 PM
  4. PrinterManager.Apply() do not save settings
    By EnDimeon in forum Third party Add-Ins, API and R&D
    Last Post: October 29th, 2012, 08:14 PM
  5. Jason Grant: #Revit Rendering Settings Follow-Up
    By Jason Grant Blog in forum Blog Feeds
    Last Post: August 10th, 2011, 01:10 PM
Tags for this Thread
