Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree4Likes
Thread: Suggested Rendering Plug-in(?)_Opinions/Recommendations/Advice
    December 19, 2014
    Scranton, PA
    2
    04:19 PM
    Question Suggested Rendering Plug-in(?)_Opinions/Recommendations/Advice
    I am a junior in undergrad, in Interior Architecture/Design, working as an Interiors Intern. The firm I work for, just started working for about a month ago rather, renders right out of Revit's rendering engine, as most people do. But, I made the inquiry about what the possibility would be of introducing a new rendering method if I was proficient enough in the program to make them look more than presentable - we do primarily healthcare and education, and I would like to breathe new life into our renderings rather than leaving them render in the cloud and post-process heavily.
    So, my question is, what are efficient rendering plug-ins for Revit that would instill more of a different and presentable quality instead of the generic feel of Revit renderings. I've worked with Maya before, but that would require more time than desired to become more proficient than the knowledge I have of it as of now. (Not saying that I would invest the time to learn it, but Maya is just one of those programs on a completely different level.) I've looked into the Maxwell plug-in, and I have experimented with Blender. But, I am looking for solid advice and recommendations.
    Let me know if I haven't been clear in what I'm stating, it's the end of the work day here and I'm down on my coffee intake, thank you!
    sm_r.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:19 PM
    Which program to use depends a lot on what your desired output is. Do you want photorealistic images or is something a little sketchy and cartoony OK? Are you doing schematic renderings or final presentation images?
    There is some talk here about different third party programs: http://www.revitforum.org/rendering-...-programs.html
    IMO - if you have the Building Design Suite take a few days to get the basics in 3DS Max and you will be good.
    December 19, 2014
    Scranton, PA
    2
    04:19 PM
    I'm looking at putting out more photorealistic images, but not hyper-realistic, something that will be convincing enough in hand with post-process work. I noticed we have 3DS Max in our program suites, and I may starting going over that again considering it's readily available in the office and through educational licensing for "out of office" refining and practice, but I will take a look at the thread you linked.
    Thanks!
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    12:19 PM
    Unfortunately, Revit is not friendly to "rendering plugins"... The ones that exist as direct plugins are not very good and need a ton of work.
    Dude, you're a student! You get unlimited cloud rendering credits!!! Use them!!! For the type of images you are explaining above it is perfect!
    For example, all of the images you see in the links below were created using Revit and Autodesk 360 cloud rendering:
    BIM After Dark - Ultimate Gallery (Part 2) | TheRevitKid.com! - Tutorials, Tips, Products, and Information on all things Revit / BIM
    BIM After Dark - Ultimate Gallery | TheRevitKid.com! - Tutorials, Tips, Products, and Information on all things Revit / BIM
    Additionally, I explain how I create all of those images in my BIM After Dark series (Volume 1). Feel free to shoot me an email and I will hook you up with a student discount!
    Cheers!
    Alex Cunningham and dzatto like this.
    Member BD Mackey's Avatar
    November 1, 2013
    466
    10:19 AM
    I think rendering out of Revit can work and will give good results. The problem is that most people hit the render button with out taking the time to understand lighting and materials. Then complain about the look and want to go to a different software. I have found the time users take to export into other software remap materials and then render takes longer than learning the tools in the native software.
    I will add Steve C Shells website here as all of his renderings are done in Revit since that is the only software he owns. He has also spoken at many conferences on how to accomplish some of the looks in his site.
    Steven C. Shell, Architect - Current Projects
    TheRevitKid and iru69 like this.
    May 22, 2012
    Connecticut
    185
    12:19 PM
    Quote Originally Posted by BD Mackey View Post
    Couldn't have said it better myself, Mr. or Mrs. Mackey?
    November 1, 2013
    466
    10:19 AM
    Realized that might be the case so I added a signature line...
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    09:19 AM
    From my experiences lighting is the largest factor for Rendering using Revit. Build yourself a few good lighting families and you are golden.
    Coeur d Alene, ID
    4,698
    09:19 AM
    Been playing with Revizto....the only issue I have had though is if I tweaked the lighting for Revit renders they are way too bright in Revizto...
    May 22, 2012
    Connecticut
    185
    12:19 PM
    Haha good call. I didn't want to say Mister and offend anyone
  1. laptop recommendations
    By fifthtexas in forum Architecture and General Revit Questions
    Last Post: November 17th, 2014, 12:33 PM
  2. Upgrading plotter, recommendations?
    By Chris Needham in forum Hardware and Infrastructure
    Last Post: March 14th, 2012, 08:18 PM
  3. suggested workflow for a building that is moved on a site?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: March 8th, 2012, 06:43 AM
  4. Replies: 67
    Last Post: January 21st, 2012, 03:27 AM
Tags for this Thread
