Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By cellophane
Thread: Nested Materials not Rendering & Stained Glass
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    04:38 PM
    I'm working on an old church and having trouble getting the stained glass in the windows to render at all. The windows are all hung windows (double / single) and I have a separate material for the top & bottom panes and everything looks correct in a realistic mode viewport - but when rendered I get nadda. I would guess it has something to do with the material itself but I'm stumped, short of recreating them all as a generic material rather than a glass material.
    The second part of the problem is that the materials are offset from the object when mapped and I have to manually adjust the map position which is... annoying to say the least - especially since the map should take up the entirety of the glass pane with no repeat.
    Any guidance is most appreciated!
    Attached Thumbnails Attached Thumbnails Nested Materials not Rendering & Stained Glass-stainedglass-window.png   Nested Materials not Rendering & Stained Glass-stainedglass-window-rendered.png
    Coeur d Alene, ID
    4,783
    01:38 PM
    August 9, 2011
    Louisville, KY
    6,140
    04:38 PM
    Thanks. I've seen it before and the only difference between his material and my material are the properties under appearance. For some reason I don't have all of the transparency settings - which gets back to having to recreate each material. I was hoping there would be a magic bullet answer but it doesn't look that way
    2014-12-16_1041 - cellophane's library
    Coeur d Alene, ID
    4,783
    01:38 PM
    I just created this one.... Since my window is 4' Diameter I had to adjust the picture 2' both X & Y so it would center. That is if I have Tile selected.
    Not using Tile, the bottom left corner is centered on the window, so I had to adjust -2'.-2' accordingly for the image to center.
    Transparency is set at 80 in the pic...
    Attached Thumbnails Attached Thumbnails Nested Materials not Rendering & Stained Glass-stained-glass.jpg
    August 9, 2011
    Louisville, KY
    6,140
    04:38 PM
    Maybe I don't understand something - but without Tile selected shouldn't the image center up automatically? That makes more sense to me than having to manually adjust it
    Coeur d Alene, ID
    4,783
    01:38 PM
    That is what I thought, until I noticed it was making the lower left corner the origin.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    04:38 PM
    Don't even try to understand Revit's UV mapping! I have found it is usually the lower left hand corner but, honestly, I feel like it is still trial and error every time I do something different.... Did you get the transparency settings?
    You started with the glazing material... If you notice in my video I change to the wire glazing material to start... That allows all the extra settings...
    August 9, 2011
    Louisville, KY
    6,140
    04:38 PM
    Quote Originally Posted by TheRevitKid View Post
    Seriously...
    For some reason I didn't have the wire glazing - but if I create a new material I get all the options I need and it seems to work.
    Thanks
    MPwuzhere likes this.
    December 21, 2010
    Phoenix, AZ
    2,599
    01:38 PM
    Agreed. Sometimes it's centered, sometimes it's lower-left, sometimes it seems random.
    May 22, 2012
    Connecticut
    185
    04:38 PM
    Seriously...
    Thanks
    Yup, that was going to be my next suggestion... Start with a new generic material and you will have all the options. As long as you have a baseline (such as my video) for the correct transparencies and reflections to get it to look like glazing.
  1. Rendering Materials
    By rfisher in forum Rendering and Gallery
    Last Post: April 23rd, 2013, 06:36 AM
  2. Rendering Materials
    By rfisher in forum Architecture and General Revit Questions
    Last Post: February 19th, 2013, 01:12 PM
  3. Revit rendering and glass
    By leetecture in forum Rendering and Gallery
    Last Post: September 27th, 2012, 08:49 PM
  4. Problems rendering transparent glass
    By thewrz in forum Rendering and Gallery
    Last Post: February 10th, 2012, 07:00 PM
  5. Revit Kid: Revit Tutorial - Stained Glass Windows
    By The Revit Kid in forum Blog Feeds
    Last Post: January 4th, 2012, 02:16 AM
