Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree6Likes
Thread: In Place Mass Rendering Problem
    June 12, 2013
    2
    04:14 PM
    I am trying to render a massing model. I want it to look like a colored acrylic model but, when I render it, the colors refract in an unusual way and it gives off a spraypaint effect where colors do show through.
    Has anyone seen this before? Any transparent material I use does this, whether is be generic mass, glass, etc.
    All help is really appreciated.
    Attached Thumbnails Attached Thumbnails In Place Mass Rendering Problem-%7B3d%7D.jpg
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    12:14 PM
    What is that blue material glowing? Is that a self illuminated material? Also, can you show some screenshots of what you are trying to create (an example image) as well as a screenshot of your current material settings?
    June 12, 2013
    2
    04:14 PM
    Quote Originally Posted by TheRevitKid View Post
    The glowing material is self-illuminated, but the problem was the same regardless of this setting.
    Attached are three concept images. I can't seem to find rendering that show what I'm trying to render.
    I have also attached two screenshots of my each material's settings.
    Thanks for your help!
    Attached Thumbnails Attached Thumbnails In Place Mass Rendering Problem-8c8124851aa57587e1562c99931a9454.jpg   In Place Mass Rendering Problem-plexi_440.jpg   In Place Mass Rendering Problem-6343913.png   In Place Mass Rendering Problem-capture.png   In Place Mass Rendering Problem-capture2.png
    May 22, 2012
    Connecticut
    185
    12:14 PM
    First, I would refrain from using self illumination for this case. Revit has a funny way of treating self illuminating objects and usually ruins the shading.
    Second, this is a major major tip for materials in Revit , always try to start with a similar material. Getting custom generic materials to work the way you want is super difficult. With that in mind... I started with a clear plastic material in Revit. Attached are my results... The first is Rendered native in Revit and the other is using Autodesk 360 Render Cloud rendering...
    I guess I shouldn't have used a white background and floor...
    I also attached the sample file so you can see the material settings.... The material is called "Mass - Acrylic"
    Attached Thumbnails Attached Thumbnails In Place Mass Rendering Problem-acrylic-mass-native-revit.jpg   In Place Mass Rendering Problem-acrylic-mass-cloud-render.jpg
    Attached Files Attached Files
    pivoarch and Ning Zhou like this.
    May 22, 2012
    Connecticut
    185
    12:14 PM
    I also did not post-process any of these... A little photoshop and context could go a long way with these....
    May 22, 2012
    Connecticut
    185
    12:14 PM
    Because I had to...
    Attached Thumbnails Attached Thumbnails In Place Mass Rendering Problem-acrylic-mass-native-context.png
    dzatto likes this.
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    298
    12:14 PM
    Now you can enter a competition for a new skyscraper.
    May 22, 2012
    Connecticut
    185
    12:14 PM
    Haha.... Architizer awards are coming up, no??
    May 22, 2012
    Connecticut
    185
    12:14 PM
    If we are going to submit it... I might as well add some detail and post-process it a bit...
    Attached Thumbnails Attached Thumbnails In Place Mass Rendering Problem-acrylic-mass-native-context.jpg
    dzatto, cellophane and Munkholm like this.
    March 16, 2011
    Princeton, NJ
    298
    12:14 PM
    Now you're just showing off. At least tell them it took you months of hard work to get it the way you wanted.
  1. railing on a sloped in place mass
    By trevorpan in forum Architecture - Family Creation
    Last Post: October 1st, 2014, 04:09 PM
  2. in place mass controll distance of added edge or profile
    By karpov005 in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2014, 07:23 AM
  3. Turning an in place mass into a stair
    By J_2612 in forum Architecture and General Revit Questions
    Last Post: April 9th, 2014, 06:09 PM
  4. In-place mass visibility
    By rjhornberger in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 7th, 2013, 11:59 AM
  5. Creating a schedule for floor areas - families and model in-place mass
    By calle_05 in forum Architecture - Family Creation
    Last Post: September 17th, 2012, 08:04 PM
