Results 1 to 6 of 6
Thread: Walkthrough Rendering
    Senior Member domsib's Avatar
    April 30, 2012
    586
    04:44 PM
    I'm trying to render a walkthrough around my building.
    I've set the walkthrough up and on another machine R>export>images and animations> walkthrough> visual style Rendering> ok> file type jpeg.
    This is one of the first images I'm getting Walkthrough Rendering-1150_me_sha_model_2014-presentation-rendered-outer-building00001.jpg
    How do I fix the rendering or alter settings or anything that is going to make it look like an actual render and not the fuzzy image that it currently looks like.
    I'm exporting as images so I can stitch together in movie maker with an internal walkthrough I have done.
    Coeur d Alene, ID
    4,697
    09:44 AM
    You need to modify your rendering settings....
    I like using these settings...But I tweak the Image Precision to 7 and the settings with 1, I change to 2. Try Luke's first then you can try mine and see the differences.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:44 PM
    You might try adjusting the size of the view also:
    Adjusting the Scale of a Camera View - The Revit Clinic
    April 30, 2012
    586
    04:44 PM
    MPwuzhere thanks. I've used these settings before, i've changed image precision to 6 and run 1 frame Walkthrough Rendering-1150_me_sha_model_2014-presentation-rendered-outer-building00001.jpg. The output is much better. Going to run the other 299 now on another machine.
    cellophane. This is really useful, I completed an interior walkthrough last week with really tight corridors and I could of done with this at the time. I'll definitely use it in future.
    Thanks
    Coeur d Alene, ID
    4,697
    09:44 AM
    Just to share....these are my favorite tweaks for stills...I change them a bit lower for walkthroughs... Last 3 can be off for exterior stills.
    7,6,8,8,5,yes,6,yes,6,6,2,yes,yes,yes
    August 9, 2011
    Louisville, KY
    6,104
    12:44 PM
    Quote Originally Posted by domsib View Post
    It is one of the best rendering tricks I've found. It doesn't really affect the render time and you can run images at a lower DPI (which does affect time) because they are bigger.
  1. How to create a walkthrough
    By domsib in forum Architecture and General Revit Questions
    Last Post: October 26th, 2013, 01:09 AM
  2. Is it possible? Render 1 walkthrough frame
    By Hilife in forum Architecture and General Revit Questions
    Last Post: August 8th, 2013, 12:14 PM
  3. walkthrough camera adjustments
    By cellophane in forum Rendering and Gallery
    Last Post: March 19th, 2012, 02:38 PM
  4. Walkthrough rendering quality & size
    Last Post: December 8th, 2011, 10:27 PM
  5. Walkthrough Animations
    By CBukowski in forum Architecture and General Revit Questions
    Last Post: April 28th, 2011, 02:23 PM
