Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree5Likes
Thread: Construction renders
    Member Bross's Avatar
    June 16, 2011
    The Netherlands
    138
    06:29 PM
    Hi there,
    I've made a construction model, and tried to render it out, so you can see some of the construction element of the building.
    I think it is somewhat over the top, for i have half cut open the building with an non visible geometry.
    A lot is going on in the image, so i've wonder if it is not to mutch.
    The original image was 43mb, so i've compressed the image to be able to upload it.
    The rendertime for this image was about a day, as i really wanted to be able to zoom in at a detail level.
    I also used 3D rebar. This was my first project that i put in 100% 3D rebar for my shedules.
    This was really fun to do, but a little more time consuming then when you only use 3D rebar there to make your details.
    Bross.
    Construction renders-b13067-45-klein.pngConstruction renders-b13067-25a.pngConstruction renders-b13067-32.pngConstruction renders-b13067-45rendertime.pngConstruction renders-b13067-48.jpgConstruction renders-b13067-50.png
    cellophane likes this.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    12:29 PM
    Hey! These are pretty neat! One suggestion that would probably cut your rendering time down is changing the chrome looking material of your steel members. Calculating all those reflections will destroy render times. Plus, I highly doubt all of your tube steel will be chrome plated in reality
    Bross likes this.
    June 16, 2011
    The Netherlands
    138
    06:29 PM
    Thanks for the reply,
    I agree on the chrome look. I've chosen this material because for me it would give you the best impression of a steel material.
    Otherwise poaple would ask me "what materials are those beams or column's. But is will indeed be of a other steel material than chrome in most of the chases.
    Thanks. :-)
    Coeur d Alene, ID
    4,696
    09:29 AM
    How's your computer running with all that modeled rebar? Know someone that did a window surround and it about killed his computer performance. (Window was only 5' wide and 9' tall...)
    10,035
    11:29 AM
    I've got a couple entire buildings of rebar. (Not a lot, but a couple). They're heavy, but not completely wrecked. Still workable. (Shrug)
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:29 PM
    Quote Originally Posted by Bross View Post
    The OOTB steel material works well enough IMO.
    Attached Thumbnails Attached Thumbnails Construction renders-steelrender.jpg
    Bross likes this.
    10,035
    11:29 AM
    I actually use a Plastic material, with a light gray color. I find all of the OOTB metal materials drastically slow down rendering, because of the MINOR reflectivity they have.
    Coeur d Alene, ID
    4,696
    09:29 AM
    This was quite a few years ago...probably working a lot better now that most machines have more than 8gb of ram now.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    11:29 AM
    You said you wonder if it's too much. Can I ask why you did them? They can't build by them (obviously). So, why spend the time to do them unless it was just for the fun of it. They do look cool, though.
    Bross likes this.
    Coeur d Alene, ID
    4,696
    09:29 AM
    I think the exploded views would look better instead of trying to cut-a-way different locations..
    Bross likes this.
  1. MEP Renders - Improvements?
    By domsib in forum Rendering and Gallery
    Last Post: January 20th, 2014, 07:28 PM
  2. Some of my Revit Renders.
    By scumbag in forum Rendering and Gallery
    Last Post: February 28th, 2013, 11:32 AM
  3. Some Interiors Renders
    By welm in forum Rendering and Gallery
    Last Post: September 12th, 2012, 01:05 PM
  4. New Interior Renders
    By Rushdog in forum Rendering and Gallery
    Last Post: October 27th, 2011, 01:05 PM
  5. renders
    By elton williams in forum Rendering and Gallery
    Last Post: October 6th, 2011, 10:33 AM
