Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By MPwuzhere
Thread: Translucent Material
    November 8, 2014
    1
    06:20 AM
    Good day,
    I am trying to generate a translucent material known as Okalux. The appearance is similar to a paper sheet, ie. light can trespass but vision can not.
    I have tried using using glass materials with bump, but it does not have the desired effect. I have also tried using 50 % transparency and 100% translucent, but does not look the same either.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:20 AM
    I think playing with the Transparency and Translucency settings is the way to get what you need. It might take some work to do but I don't see why you couldn't get the desired result. Start with Transparency at 100 and Translucency at 25 and increase it by increments of 5 or 10 - then swap your values and try again. Somewhere along the way you should get what you need.
    http://www.renderplus.com/wp2/wk/Translucency.htm - not Revit specific but it's a good starting point on the different settings.
    December 21, 2010
    C.LONDON
    4,353
    05:20 AM
    Quote Originally Posted by equ327 View Post
    Although I agree with Chad that this should be possible with enough fiddling with the appearance settings, perhaps you might consider a material with luminescent properties to experiment with also? I once made a Shoji screen and opted that for a quick-fix once myself but sadly no longer have the file.
    Coeur d Alene, ID
    4,698
    09:20 PM
    I have been trying to get a translucent material to work myself....finally it somehow just "started" working...
    And I was just trying to get the film over the windows and doors...
    Attached Thumbnails Attached Thumbnails Translucent Material-council-chambers.jpg
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    09:20 PM
    that table is Way Cool!
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    12:20 AM
    I have not tried this yet, but in my mind it is working... How about if you apply a plain white image to the material... It would be similar to what I did here to make stained glass...
    Revit Tutorial - Stained Glass Windows | TheRevitKid.com! - Tutorials, Tips, Products, and Information on all things Revit / BIM
    Instead of the stained glass image use a plain white image...?
    Just thinking that it might get a better result than simply messing with Revit's transparency, etc....
    I will give it a try when I get a chance.
    Coeur d Alene, ID
    4,698
    09:20 PM
    Quote Originally Posted by TheRevitKid View Post
    Didn't check out the video....but adding the image helped what I was trying to do.
    TheRevitKid likes this.
  1. Rendering Translucent Concrete
    By Arcitct in forum Architecture and General Revit Questions
    Last Post: July 26th, 2014, 09:16 PM
  2. [urgent]translucent polycarbonate facade
    By chiuchunkit in forum Architecture and General Revit Questions
    Last Post: April 1st, 2014, 09:34 PM
  3. making my glass translucent in screen elevations?
    By gentlepuppies in forum Architecture and General Revit Questions
    Last Post: July 11th, 2013, 10:20 AM
  4. making my glass translucent in screen elevations?
    Last Post: July 10th, 2013, 10:56 PM
  5. Translucent Glass in Elevation
    By Jack in forum Architecture and General Revit Questions
    Last Post: November 30th, 2011, 07:25 PM
Tags for this Thread
