Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree8Likes
Thread: Renderings out of Revit linked to 3dsMaxDesign always missing some 'Level' in PS
    December 13, 2010
    Ambleside, Lake District, UK
    950
    09:55 PM
    Just wondered if anyone knew why, for as long as I can remember (so, not that long ) still rendered images created by iRay in 3dsMD from a Revit model linked in to 3dsMaxDesign (v2015, 2014 at least) has the bottom area of the 'Levels' adjustment dialog in Photoshop missing (see attached).
    I can drag the bottom right slider along until it meets the start of the graph slope which sort of seems to improve the image, but even using an HDRI image for lighting the render I don't get any presence in that area of the graph.
    Not a huge problem but it has long puzzled me and I wondered if anyone could suggest a technical reason of what I might be doing wrong?
    Thanks.
    Attached Thumbnails Attached Thumbnails Renderings out of Revit linked to 3dsMaxDesign always missing some 'Level' in PS-missinglevels.jpg
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    348
    08:55 AM
    wouldn't have a clue, but really nice Render
    Building looks good & Materials look great
    December 13, 2010
    950
    09:55 PM
    Thanks, kind of you to say
    Every building I do uses the same slatestone, roughcast, green roofing slate in diminished courses and random widths, which I created 15 years ago from photographs of a small building 50 yards from my office.
    This is a simple domestic garage converted to a dwelling.
    I find that using the standard sky in Revit or 3dsMaxDesign (using Mental Ray) gives quite hard shadows whereas we live in a rain-soaked area where bright sunshine is unusual. Adding a 'skylight' to the linked project in 3dsMaxDesign and switching off the Mental Ray sky and Exposure control, and assigning an HDR image ('high dynamic range' image I think it means) to the skylight seems to give a softer, flatter light which in our climate looks more realistic (even though you might have to rotate the HDR image to accord with where the sun should be in the scene).
    However, the resulting images (from the iRay renderer option in 3dsMaxDesign which works with Nvidia graphics cards - a K4000 in my case) seem to lack this 'bottom end' when viewed in Photoshop's Image Adjustment->Levels which seems odd.
    December 21, 2010
    Phoenix, AZ
    2,599
    01:55 PM
    I think you just explained what's going on... all those settings you changed to make the image softer and flatter is killing your dynamic range. There just isn't enough illumination to get what whites (what I would call the upper range of the histogram) you have in the model a chance to pop.
    jpeter78 likes this.
    December 13, 2010
    950
    09:55 PM
    Sounds logical to me - thanks very much
    December 13, 2010
    950
    09:55 PM
    Tada! Result
    Thanks to GMcDowellJr pointing me at the right area I noticed 'Use Scene Environment' wasn't checked in the skylight parameters in 3dsMD2015.
    Now we have some graph in the previously missing area.
    cheers
    Attached Thumbnails Attached Thumbnails Renderings out of Revit linked to 3dsMaxDesign always missing some 'Level' in PS-frontview18thjuly2014.jpg
    December 21, 2010
    Phoenix, AZ
    2,599
    01:55 PM
    Looks better already!
    December 13, 2010
    950
    09:55 PM
    Thanks - but I now think that was just luck - there is something in that rendering which isn't in others, but something in the light source settings must be where the problem lies.
    Incidentally, I came across this neat tutorial on the 'Levels' tool in Photoshop which suggests it isn't always right to just drag the sliders left and right to the edges of the histogram:
    Using the Photoshop Levels Tool
    December 13, 2010
    950
    09:55 PM
    After more experimentation sticking with the MR Sky in the 3dsMaxDesign daylight system and rendering with iRay, and picking a good time of day seems to give the best results in the Levels dialog in Photoshop so I'm seeing more consistently 'bright' results.
    I never let renders go beyond 30 minutes so iRay does well enough for my little jobs
    Attached Thumbnails Attached Thumbnails Renderings out of Revit linked to 3dsMaxDesign always missing some 'Level' in PS-yard-entrance.jpg
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,489
    01:55 PM
    Quote Originally Posted by willsud View Post
    I like the corner detail, looks like a box joint used in drawer construction. That's a house that the Big Bad Wolf couldn't blow down for sure
    willsud likes this.
  1. Missing elements in linked file RVT
    By tomek64 in forum MEP - General
    Last Post: July 15th, 2014, 08:01 PM
  2. Created Section View. SOME level heads missing.
    By doni49 in forum Architecture and General Revit Questions
    Last Post: January 14th, 2014, 04:52 AM
  3. New Linked Model, Spaces & Room Names Missing
    By JamesLawrence in forum MEP - General
    Last Post: August 23rd, 2013, 05:03 PM
  4. Revit to 3dsMaxDesign Workflow
    By duckiemama in forum Rendering and Gallery
    Last Post: July 15th, 2013, 10:52 PM
  5. Replies: 0
    Last Post: January 27th, 2012, 01:15 PM
