Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree4Likes
Thread: High Acuity Room
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    06:49 AM
    High Acuity Room
    Finally got around to pursuing another room in the hospital last weekend. Its not quite what I hoped, but its the first test render off the block.
    Its Revit + 3dsMax. I played with the vignetting (dark corners) a little too much. Comments?
    Attached Thumbnails Attached Thumbnails High Acuity Room-testimage_highacuity.jpg
    cganiere likes this.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    08:49 AM
    Are the cabinets supposed to have a mirror finish? The rest of the glass looks great but the cabinets look like they are faced with a mirror. It could just be a result of angles but it throws me.
    The spot in the fixtures where the lights are is a little lacking but I know that's a royal pain to get right.
    Overall it's pretty good!
    August 15, 2012
    USA
    191
    06:49 AM
    I think at the last second I took the glass reflective numbers from 12 to 30 (direct and oblique) and probably need to adjust the transparency as well. I'm probably going to rebuild the stretcher in there. The sharp edges on the blue cushion bug me. The light fixtures or the lights on the boom? I plan on developing that boom a lot further. The floor needs some work too. This was the first render out of the shoot, thanks for the catches. I would've overlooked the mirrored affect.
    August 9, 2011
    Louisville, KY
    6,104
    08:49 AM
    All of the lighting. It looks like a light emitting surface instead of a light with a cover. Again - I know that's a huge pain to get right and most folks probably wouldn't notice
    Autodesk Steven_Campbell's Avatar
    December 21, 2010
    San Antonio, TX
    19
    07:49 AM
    The cabinets need a bigger gap between the doors, typically some where between 1/8" to a 1/4" will make the panels standout correctly.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    08:49 AM
    OP. Nice stuff. I think the level of detail is well done and I agree with the comments above. I hint of reveal in the cabinet doors would help, and the glass is definitely a bit too reflective. The glass ruins the "realism". I like the details of the switch on the wall, etc... I also think you need to check out the materials of the small chair against the casework. Something looks funny there.
    Also, because I enjoy doing so... I took a stab at a bit more post production for you. It has a different feel and is a bit grainy, but I thought I would throw an example at you.... What do you think??
    Hirvio likes this.
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    251
    02:49 PM
    Quote Originally Posted by TheRevitKid View Post
    What do you think??
    There is no reflection of the doctor in the glass...
    Member Barrie's Avatar
    August 3, 2011
    Kent, UK
    217
    01:49 PM
    That's because he's Nosferatu.
    Sent from my Windows Phone
    JeffH and Alex Cunningham like this.
    May 22, 2012
    Connecticut
    185
    08:49 AM
    Quote Originally Posted by Hirvio View Post
    Haha... I do not have a "front" image of him!
    August 15, 2012
    USA
    191
    06:49 AM
    Looks great Jeffrey! No worries about the reflection, there's always some way around it, you can always place the doctor in a different location.
  1. Replies: 0
    Last Post: January 30th, 2013, 12:15 PM
  2. Replies: 0
    Last Post: January 28th, 2013, 12:15 PM
  3. high-end laptop
    By mdradvies in forum Hardware and Infrastructure
    Last Post: September 30th, 2011, 12:11 AM
  4. Mmmm High Speed Net
    By Alex Cunningham in forum Out There
    Last Post: April 25th, 2011, 10:26 PM
  5. High End Cabinet Families
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2011, 01:44 AM
