Results 1 to 4 of 4
Thread: only 1 CPU for rendering
    February 13, 2014
    2
    07:30 AM
    Hello,
    I'm running Revit on Windows 7 on a partitioned iMac with Intel Core2 duo processor. However, it only renders with one box at a time. I assume that means it's only using one CPU thread. Is that correct?
    Rotterdam, South Holland
    3,042
    02:30 PM
    I wouldn't trust the boxes on screen. Use Task Manager and the Performance tab. With that CPU I think you should see four traces in CPU history (2 'real' cores and 2 'virtual' cores thanks to hyper threading). The first stage of rendering half will be pegged while the other half are less than maxed out, and in later stages of rendering everything will be maxed out. Anything else and something is amiss.
    Gordon
    February 13, 2014
    2
    07:30 AM
    OK, thanks for clarifying. A previous install of V-Ray used to show multiple boxes, so I thought that was an indicator of cpu usage.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    06:30 AM
    All your processors are focusing on that one box at a time in Revit. 3dsMax and Maya separates them out into many boxes. I bet Revit is using all your cores when you process.
  1. Replies: 0
    Last Post: August 17th, 2013, 06:15 AM
  2. First Rendering
    By luiszavarq in forum Rendering and Gallery
    Last Post: April 2nd, 2013, 09:24 PM
  3. Rendering Materials
    By rfisher in forum Architecture and General Revit Questions
    Last Post: February 19th, 2013, 02:12 PM
  4. Rendering
    By derio in forum Rendering and Gallery
    Last Post: August 14th, 2012, 04:45 PM
  5. Revit Rendering
    By Chang Lee in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 1st, 2011, 09:12 PM
Tags for this Thread
