Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Texture map
    September 26, 2011
    119
    11:57 PM
    Texture map
    All,
    I am rendering a custom texture mapped 'expanded metal mesh' panel.
    but final rendering shows two layers of textures on top of each other.
    it seems like it is rendering both front anc back face surface.
    is there a way to fix that?
    please see the attachment for clear understanding
    Lee
    Attached Thumbnails Attached Thumbnails Texture map-7271_8th_and_filbert_clee.rvt_2013-dec-05_12-33-48pm-000_r2_8th_and_filbert-looking_up.jpg
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    02:57 AM
    Can you post a piece of the geometry with the material attached?
    September 26, 2011
    119
    11:57 PM
    dzatto's Avatar
    December 9, 2010
    5,234
    02:57 AM
    I saw the pic, I'm asking if we can see an actual piece of geometry with the material attached so we can troubleshoot it in Revit.
    September 26, 2011
    119
    11:57 PM
    how am i suppose to attach the model?
    i dont see 'attachment' icon anymore
    dzatto's Avatar
    December 9, 2010
    5,234
    02:57 AM
    You'll have to strip it down probably. But if you edit your post, or start a new one, there will be a button on the lower right that says "go advanced". Hit that and it will open up some more options, one of which is attach a file.
    September 26, 2011
    119
    11:57 PM
    Texture map cutouts
    here is the model with texture map.
    trying to render a panel with cutout texture and somehow it is rendering both back and front surfaces.
    how do i make it render only oneside
    Attached Files Attached Files
    dzatto's Avatar
    December 9, 2010
    5,234
    02:57 AM
    Your expanded metal cutout map didn't come through, but I used one of mine and it rendered as it should. So, I think the map may have something wrong with it. Can you upload the map as well?
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    03:57 AM
    The only way to get a single face is using a mass. Otherwise you will always be cutting two surfaces. You could try making it something like 1/16" thick but you are not guaranteed that the cut holes will be aligned...
    I have had similar issues and simply made a single faced mass for the steel mesh.
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    585
    09:57 AM
    Quote Originally Posted by TheRevitKid View Post
    You can align a texture with a model pattern, and you can move a model pattern around as much as you like. Only thing is that in order to be able to see the cutout when aligning it with the model pattern, you need to add the image as a material map as well.
    Still, single faced mass is a lot more simple. I'd go with that one if it's a one off.
  1. Map Channels - Procedural / Texture
    By cellophane in forum Rendering and Gallery
    Last Post: March 16th, 2013, 06:43 PM
  2. Texture sharing between users?
    By theclaus in forum Architecture and General Revit Questions
    Last Post: September 4th, 2012, 10:17 PM
  3. Problème de texture de mur
    By Andjetya in forum Forum Français
    Last Post: June 25th, 2011, 05:36 AM
  4. Custom material texture: three files?
    By Gordon Price in forum Rendering and Gallery
    Last Post: May 21st, 2011, 08:26 AM
  5. question of showing texture while view 3d
    Last Post: April 27th, 2011, 09:46 PM
