Results 1 to 10 of 10
Thread: Interior lights not "on"
    August 1, 2013
    ABQ
    200
    12:38 PM
    The lights from the architectural link are "on" as shown in the image. However, I am stumped on how to get our lighting to work. My guess is this is not a difficult task. What do I have to do to use our lighting when redering?
    August 1, 2013
    ABQ
    200
    12:38 PM
    FWIW, we have not spent time with rendering. As an MEP firm we are obviously focused on our systems, etc. From a marketing standpoint we really need to learn how to showcase our design.
    Coeur d Alene, ID
    4,783
    01:38 PM
    Do your light families actually have light objects in them? Some firms just show the symbols and leave out the light objects to save on file size.
    August 1, 2013
    ABQ
    200
    12:38 PM
    I work on our mechanical side. I assume you mean what is in the attached pictures.
    Attached Thumbnails Attached Thumbnails Interior lights not "on"-fixture.jpg   Interior lights not "on"-fixture1.jpg
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    03:38 PM
    Check your rendering setup (Lighting>artificial lights). You can turn lights on and off individually or by groups (if you grouped some lights together). Maybe they are turned off there?
    August 1, 2013
    ABQ
    200
    12:38 PM
    Well, one thing I noticed was that electrical's light were not set to cut the ceiling. Perhaps it would help if the fixtures cut?
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    04:38 PM
    That may be most likely your culprit. The light emitter is probably embedded in the ceiling
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    04:38 PM
    I would say check to make sure the start of the light source is not inside the ceiling... Also, sometimes you need to force Revit to find the IES file.
    I would go with the ceiling first.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    04:38 PM
    I know you asked specifically about the lights but a couple things jumped out right away to me when I looked at this - even before I noticed the lights. My notes are on the attached image. It's a nice image overall but the little things add up and can detract quite a bit. If this is for marketing you want it to be as tight as possible.
    May 22, 2012
    Connecticut
    185
    04:38 PM
    Oh come one.... you never saw a Mirrored Elevator door?!
    My guess is the dust collector below the stairs is a ceiling and needs some soffit walls.
    I would also add that putting a background image (either within Revit or post production) would help alot with the windows... Right now it looks like the building is floating in the stratosphere.
  1. "Gross" as opposed to "Net" Area Take-Off for Walls
    By SuperDave in forum Third party Add-Ins, API and R&D
    Last Post: July 26th, 2013, 03:52 PM
  2. Show Room "Interior Fill" on an Area Plan
    By darryl in forum Architecture and General Revit Questions
    Last Post: August 29th, 2012, 01:25 PM
  3. Replies: 0
    Last Post: February 9th, 2012, 01:15 AM
  4. How do you choose which category "wins" (Lights & Such)
    By snowyweston in forum Architecture - Family Creation
    Last Post: October 14th, 2011, 07:50 AM
Tags for this Thread
