Results 1 to 3 of 3
Thread: Painted Masonry Material Maps
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    06:01 PM
    I'm not having much luck with searching for this on the internets - does anyone know how to create painted masonry (brick / CMU)? I have Masonry Designer so getting the bare block isn't an issue but I can't figure out how to apply a paint color to the image for my map. I'd like to figure out how to do it so I don't have to try and find one that is close to what I need every time.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    05:01 PM
    Try making your material (in revit) a generic material. Then, there's a color slider where you can mix in a color you pick.
    Munk showed me this for some brick I was having trouble coloring. The thread is on RFo somewhere. I'll try to find it.
    HERE it is.
    August 9, 2011
    Louisville, KY
    6,190
    06:01 PM
    Thanks. I've read that before and apparently am over thinking all of this...
  1. How do I find out what material something has been "painted"?
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2013, 01:20 AM
  2. material painted with an angle help!!!!
    By sixingno1 in forum Architecture and General Revit Questions
    Last Post: November 29th, 2012, 10:05 AM
  3. Moving material maps
    Last Post: September 27th, 2012, 06:30 PM
  4. OBJ model with maps/textures?
    By cliff collins in forum Rendering and Gallery
    Last Post: January 24th, 2012, 07:05 PM
  5. Sub maps in schedules ???
    By Devlin in forum Architecture and General Revit Questions
    Last Post: November 13th, 2011, 08:34 PM
