Results 1 to 8 of 8
Like Tree7Likes
  • 1 Post By snowyweston
  • 1 Post By JCM
  • 5 Post By TheRevitKid
Thread: Test interior render
    July 14, 2012
    10
    11:51 AM
    i feel its not enough!
    December 21, 2010
    C.LONDON
    4,382
    12:51 PM
    Quote Originally Posted by phamtuan View Post
    In what way?
    Let's talk about the good bits - the detail, in the building and furniture/object elements, is pretty good - as are most of your materials (red sofa, curtains, steps and piano less so) and you've got a "shape" to your camera views (no obvious sign of forced perspectives)
    but
    The colour (artificial) is certainly too warm - unless that's your intent - and you would do well to brighten it up/go for a more neutral white - for the style/decor I'd even so go cool-white with the colour. Equally, as nicely framed your shots are, I'd maybe look to composing them a little more dynamically (look into photography's rule of thirds) to move the eye and focus around your images.
    TheRevitKid likes this.
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    07:51 AM
    In addition to what snowyweston said...
    Given that you have a lot of nice details in your rendering...
    You can "fillet" the edges of sofas using a 1/2" - 1" radius. This will make your furniture look less boxy.
    The pillows on your sofa look unnatural... I would change their proportions to be a little more square. If they are going to be rectangular, I would rotate them 90°
    The curtains on your sliding doors should reach the floor, they look unnatural (I personally would have all the curtains reach the floor, including the ones on the windows)
    Finally the photos on the wall should be different specially if they are on the same wall.
    HTH!
    July 14, 2012
    10
    11:51 AM
    Sorry my English so poor!
    ok, thanks guys, i agree your mean, and i'll repair in the next time.
    So have you got some families like sofa, curtain ,,, if you have, may be send to me
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    07:51 AM
    The curtains you have seem to be a simple extrusion. Just edit the family to increase the length of the extrusion of curtains.
    For the sofas open the families you have and look into creating void sweeps to create the fillet.
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    07:51 AM
    I agree with everything mentioned above by JCM and snowy... The one thing I will add is that you should look into a hint of post-processing too. For example, here is your rendering with a few minutes in photoshop... Revit can do A LOT of things but I never suggest saving a rendering without a little post processing.
    JCM, snowyweston, muttlieb and 2 others like this.
    December 20, 2010
    1,057
    07:51 AM
    Like others, you have a good foundation to work from. Do a little post processing in the white point setting in revit or in PS and you'll be good to go.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    05:51 AM
    Just that slight adjustment that Jeffrey made was a big improvement. All the colors seem more life-like. Revit almost always gives off that yellowish tone. Of course, its adjustable in the light/exposure settings before you save it. The red corbu-chair needs work.
  1. Cloud render compared to 3dsMaxDesign 2013 render (internal)
    By willsud in forum Rendering and Gallery
    Last Post: September 6th, 2013, 09:27 AM
  2. Replies: 39
    Last Post: February 8th, 2013, 04:55 PM
  3. Render Gurus: validate my test process
    By Gordon Price in forum Rendering and Gallery
    Last Post: June 2nd, 2011, 04:57 AM
