Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By snowyweston
  • 1 Post By Scott D Davis
Thread: Soft Cushions
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    10:37 PM
    Soft Cushions
    Does anyone have a technique for creating soft cushions for interior renderings? All the ones I have seen are usually boxy.
    or at least some way to make them render nicely?
    Junior Member ArchTech247's Avatar
    July 13, 2011
    Longview, Texas
    25
    08:37 PM
    Void sweeps along the hard edges work well.
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    10:37 PM
    Yeah I thought about that and while it does give a softer edge, the pillows themselves still feel boxy. They don't feel nice and soft.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    10:37 PM
    Explore the use of adaptive families/mass families.
    December 21, 2010
    C.LONDON
    4,382
    03:37 AM
    Google:
    "revit cushion" for Andy's method
    or
    "revit pebbles" for Zach's method
    = first results
    Sometimes this place isn't the first place you know!
    MrBIMtastic likes this.
    10,179
    09:37 PM
    Opinions on this subject vary, but if you venture in to using Mass families or Adaptive Components to make nice cushions for your furniture, i hope you have one BEASTLY machine for handling your models, if you plan on doing a full FFE package in that building... Because its going to get stupid large.
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    655
    07:37 PM
    Render in Max using a modifier on the cushions to soften the edges. You can link a Revit 2014 file into Max 2014, and then the Max file can be updated as the model changes in Revit, but modifiers/materials/etc in Max will retain their properties.
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    10:37 PM
    Quote Originally Posted by Scott D Davis View Post
    While this would be my prefered method, unfortunately I don't have access to MAX
    With regards to adaptive components I like the Idea and will look into it further...
    Fortunately I only need them for rendering purposes so I can always unload them after the fact.
    Thanks Everyone for your input!
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    08:37 PM
    Someone out there is experimenting with all RPC furniture with very good results. Lightweight models and quality rendering possibilities. Not sure I'm sold on the idea, but I think it was floating around on....dare I say it..... Revitcity forums...?
    Should get you the "softness" cushions you're looking for, IF you have an RPC maker or know how to make them.
    10,179
    09:37 PM
    It'll look great in realistic and rendering modes, won't look great in hidden line or shaded modes. If you're going to go to that length I'd just DFC for rendering and swap them out, or link.
    Unless you have a way to add your nice Revit geometry over the top of an RPC family. I don't recall what the issue was, but I remember it not working that way when I tried last time. Can you control RPC cutouts with Revit level of detail?
  1. BimBlog: 3 "Soft" Benefits of BIM
    By BimBlog in forum Blog Feeds
    Last Post: November 30th, 2012, 09:15 AM
